Go to Post I've now read Dolly Parton's entire wikipedia page, which was not something I expected to do - WinterPoet [more]
Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
  #46   Spotlight this post!
Unread 17-01-2015, 10:39
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
Re: Anyone heard more about the Ekocycle 3D printer?
As a quick exercise on how much the filament for the Ekocycle 3D printer actually costs, I did a bit of detective work. While the machine itself is reasonably priced, the actual amount of filament you get in the $50 cartridges is conspicuously absent from their website. While they do not state it, they do give some hints:
Each EKOCYCLE cartridge contains 25% post-consumer recycled materials, using an average of 3 assorted recycled 20 oz. PET plastic bottles.
I did a little research and I found that you get approximately 19 20 oz bottles per pound of PET. From this we can calculate that each bottle is 0.84 ounces (16oz/19bottles) or 23.81 grams. Then from the blurb on the 3D Systems website we see that each cartridge contains 25% recycled plastic which is about equivalent to 3 bottles. From this we can conclude that each spool is 285.72 grams (23.81 * 3 * 4). Now that we have grams per cartridge we can actually figure out the cost per kilogram, which is..... Drum roll please..... $175 per kilogram. The most expensive non 3D Systems equivalent to this filament is Tauluman t-glase which cost about $70/kg. There are a few suppliers making PETG filament for $50/kg.
  #47   Spotlight this post!
Unread 17-01-2015, 12:14
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Team Role: CAD
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
Wow, that's pretty expensive. I wonder how difficult it would be to swap control boards with one that allows printing anything. You could easily recoup the cost after a few kg of plastic.
  #48   Spotlight this post!
Unread 17-01-2015, 12:57
AKA: Matt Hagan
Not terribly hard, but you need to have a pretty good understanding of how the controls work.
Off the shelf solutions like the RAMPS 1.4, Rambo board, and Smoothie board are readily available. All of these are going to require some modification to the firmware to make them work.
  #49   Spotlight this post!
Unread 17-01-2015, 16:36
golden_warrior5's Avatar
golden_warrior5 golden_warrior5 is offline
FTC #7491
golden_warrior5 is an unknown quantity at this point
Originally Posted by Quazar View Post
We just received ours today as well, but we are having trouble activating it. The Cubify website is telling us the serial number is invalid (we've rechecked it about a dozen times).
Anybody else having this problem?
- Dean
[EDIT] I just got it activated - I kept submitting the same S/N, and it eventually worked. If you hit this problem, just keep trying I guess. [/EDIT]
I am having this same problem. I have tried a few dozen times now but it won't go through. This whole business of having to activate a piece of hardware seems like a waste of time and resources to me. Too bad they weren't giving out something tried and true like a Makerbot.
Also, our printer did not ship with the "included" flash drive.
  #50   Spotlight this post!
Unread 17-01-2015, 17:12
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
We had that error as well. Emailed Cubify tech support, gave them the serial number and they simply gave us the activation code. Real simple (Though would rather have not had to deal with it).
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
  #51   Spotlight this post!
Unread 18-01-2015, 12:45
ksanger's Avatar
ksanger ksanger is offline
FRC #0211 (MaK)
ksanger is on a distinguished road
Anxiously awaiting word on when ours might ship. Emailed them today. I expect it will be difficult to setup and create a part in time for this years robot.
  #52   Spotlight this post!
Unread 20-01-2015, 17:14
rockychat3 rockychat3 is offline
FRC #4859
rockychat3 is an unknown quantity at this point
Is it possible to use any PET as long as you load it into their special cartridges? The printer is super cool but I'm terrified to use up the included spools at $50/each!
Example: http://www.amazon.com/MadeSolid-PET-.../dp/B00PH4D5P6
  #53   Spotlight this post!
Unread 20-01-2015, 17:22
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Nope, the cartridges contain a chip that stores filament type and length remaining. As filament is extruded the printer updates the length remaining value on the chip. When that value hits zero the printer will refuse to print even if filament is available.
2016: FRC 865 Mentor
  #54   Spotlight this post!
Unread 20-01-2015, 18:47
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Originally Posted by marshall View Post
Thank you for this! We use Solidworks but we've had a really hard time with the scaling and this printer. We'll give this a shot and see where we land.
Marshall,
We've only printed one item on our (had trouble with the cartridge jamming), but saving it as an stl file from Solidworks, opening it in the cubify software and sending to the printer - the scaling was perfect.
T.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
  #55   Spotlight this post!
Unread 20-01-2015, 19:00
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
I truly believe that the cost-prohibitive nature of this filament is going to cause exactly this to occur...as soon as the warranty expires, users that got one of these will figure out how to hack it into printing bulk PLA or something affordable. Cubify has to realize that a machine like this just can't compete against printers you can buy for less than $1000 that use filament you can get for $18.00 a kg.
  #56   Spotlight this post!
Unread 20-01-2015, 21:44
marshall's Avatar
marshall marshall is online now
FRC #0900 (The Zebracorns)
Originally Posted by Qbot2640 View Post
Marshall,
T.
We had issues with scaling that we have since figured out. We're abusing it at the moment to print all kinds of stuff. It seems to pick which filament it wants to print with randomly. The software is a bit confusing.
One thing is for certain, once it is out of filament it is probably going to be liberated from its proprietary nature.
  #57   Spotlight this post!
Unread 21-01-2015, 16:22
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
Originally Posted by zachrobo1 View Post
Has anyone not received theirs yet? We placed an order on December 9th and it still hasn't shipped. Time to contact Cubify I guess..
We've paid for shipping, but still no sign of ours yet. Feels like we've been waiting a while. I'm not expecting to use it much during build anyways, but hoping it comes soon.
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
  #58   Spotlight this post!
Unread 21-01-2015, 16:36
galewind's Avatar
galewind galewind is offline
... more like a temperate breeze
AKA: Chris Gregory
FRC #1089 (Team Mercury)
galewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond repute
Send a message via AIM to galewind
Ours came late yesterday (after I went home).
I went home sick today, so I didn't have a chance to explore it.
Chris G
Advisor, Team Mercury (1089), Hightstown High School
  #59   Spotlight this post!
Unread 21-01-2015, 16:42
Joining the 900 Meme Team
FRC #0079
I wonder if there's a way to tweak that similar to how you can mess with the toner cartridges from Brother printers.
Could be a fun student exercise.
  #60   Spotlight this post!
Unread 21-01-2015, 20:21
AKA: Matt Hagan
probably not. I would guess that they use an encrypted tag. I know that they did on the HD3500 cartridges. Breaking the encryption proved to be non-trivial. I would imagine they did something similar here since they have the tech worked out elsewhere previously. Unlike the HD3500 there are open source alternatives for the controller hardware for the Cube. Instead of trying to crack the encryption your are probably better off just switching the controller board out for a Ramps 1.4, Rambo, smoothie board, CRamps etc.
