Go to Post You can't lose if you submit an animation. Even if you don't win an award, your team wins by just doing it. - David Brinza [more]
Unread 21-01-2015, 17:39
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Factory reset a RoboRIO?
We were testing our roboRIO and rebooted the robot in the process. When the robot booted up, the roboRIO became totally unresponsive. I can't get any comms to it through WiFi, Ethernet, or USB. The flasher tools and 172.22.11.2 aren't able to connect.
I'm looking through the roboRIO user manual for a factory reset function and I can't seem to find one. The "reset" key only boots the roboRIO into safe mode.
How do I completely reset the roboRIO to factory reset mode? or atleast if anyone has had similar symptoms to what I am experiencing?
Unread 21-01-2015, 18:55
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Re: Factory reset a RoboRIO?
Originally Posted by NI FIRST
During the build season, you can call NI phone support at 866-511-6285 between 1:00 - 7:00 PM CST on weekdays.
If you need to replace a roboRIO, please call 866-511-6285.
National Instruments has a phone line dedicated to helping FIRST teams; while I have not used it for getting roboRio help, I've used it in the past for cRio help and they're incredibly friendly and crazy helpful.
Academic Student (Forever)
Unread 21-01-2015, 20:55
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Thanks for the #, I'll have to use it sometime. Apparently the built-in mDNS resolver on the roboRIO isn't working, I had to enable the mDNS on the router and connect through the router instead. Silly that this completely disables straight-through ethernet as well as USB (which is proclaimed as "the only safe way to image the device")
