Go to Post Use sensors to collect data about the surrounding environment, then discard it and drive into walls. - Jared Russell [more]
Unread 21-01-2015, 18:36
question question is offline
FRC #2472
question is an unknown quantity at this point
Smartdashboard problem
The smartdashboard is not displaying values when connected to the roborio. it is receiving the ip address properly and it has not lost our team number. The code is loaded properly into the roborio. Any suggestions would be much appreciated.
Unread 21-01-2015, 19:56
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
TogetherSword8 is an unknown quantity at this point
Re: Smartdashboard problem
Some questions:
1. Are you able to run your robot?
2. Is your computer on an auto ip configuration?
3. Did you properly re-image your router?
If question number 1 is no, the answers to 2 and 3 might also be part of your problem.
I program a robot. Which means I write code and everyone gets mad at me when something doesn't work, even if I am the only one that knows it doesn't work. The key part to know is that the robot never works.
Unread 22-01-2015, 18:22
FRC #2472
We are able to run our robot, we are on an auto ip configuration and we were able to re-image the router properly
Unread 23-01-2015, 19:05
Is the connection indicator showing a connection? http://wpilib.screenstepslive.com/s/...smartdashboard
Are you using the 2015 smart dashboard?
