Go to Post IMHO, [the driver's] job is to drive the robot. The coaches job is to monitor everything in a match that isn't your robot. - CalTran [more]
Thread Tools Rating: Thread Rating: 29 votes, 5.00 average. Display Modes
Unread 21-01-2015, 20:33
slibert slibert is online now
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Re: ANNOUNCING: navX MXP Robotics Navigation Sensor
Originally Posted by ayeckley View Post
Scott,
I too am having difficulty running the UI. If I execute (from a Command window) navXMXPUI.exe, nothing happens and no errors are generated. If I execute navXMXPUI.bat (edited as specified to point to COM4, which is where the ST VCP is connected), I get an error "Could not find or load main class NAVXMXPUI". I am able to run navXConfig (setup.exe) with no issues which leads me to believe both the PC and navX hardware are configured properly.
I'm using Win 7 (64 bit), and have Java 1.7 runtime enabled under User settings (1.8 is also installed, but I have disabled it). I've also installed Processing 2.2.1 (2.1 is not listed as a downloadable release) and have copied the "processing" directory to the specified location. I am not able to "Open the Processing IDE and then open the navXMXPUI sketch via the "File->Sketchbook menu" because there are no selections available ("Empty Sketchbook" appears, greyed-out). I can open the .pde successfully using the File/Open dialog, however when I attempt to compile it I get the same library errors as a previous poster reported (no library found for com.kauailabs etc.). When I "Show Sketch Folder", the navXMXPUI folder (and its subfolders) is displayed as one would expect.
Where have I gone wrong? I suspect it's something in my Java configuration.
Building the navXMXPUI with the Processing IDE 2.2 has an issue we haven't fixed yet, I think that's causing your issue.
The pre-built binary in the navxmxpui\application.windows64 directory should work on 64-bit windows if java 1.7 is installed, it's built with processing IDE 2.1. Looks like the link to the 2.1 IDE has been removed.
