Go to Post FIRST is the only high-school sport where everyone can become a pro - David Brinza [more]
Unread 21-01-2015, 19:23
rawrpenguinlion rawrpenguinlion is offline
FRC #0008
rawrpenguinlion is an unknown quantity at this point
Methods are not being called
We have what should be working code with no syntax errors, but when we deploy to the robot nothing happens. We put print statements in many methods to check if methods were being called, including RobotInit(), TeleopInit(), and TeleopPeriodic(), but nothing prints. Any advice? Thanks.
Unread 21-01-2015, 19:32
Darkseer54's Avatar
Darkseer54 Darkseer54 is offline
Former Controls Captain and Driver
AKA: Zach Kaplan
FRC #1086 (Blue Cheese)
Darkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of light
Re: Methods are not being called
Do you have WPIlib.h included? Also, are you using java or C++?
Thanks,
Zach
2014: IRI on a losing record.
Unread 21-01-2015, 19:49
FRC #0008
Yes, we included WPILib.h
We also use C++, not Java.
Thanks.
Unread 21-01-2015, 20:07
Darkseer54's Avatar
AKA: Zach Kaplan
Are you sure you installed the frc toolchain correctly? When you look in your includes folder on the left toolbar (forgot what it's called) is WPIlibrary there? Also are you having problems with the functions themselves, or just printing?
Thanks,
Zach
Unread 21-01-2015, 22:13
JefferMC JefferMC is offline
AKA: Jeff Corbett
FRC #1319 (Flash)
JefferMC will become famous soon enough
Can you confirm any aspect of your program being loaded? i.e. is the Program communication indicator on on the dashboard? Where are you looking for the text messages? Have you tried the tab in Eclipse?
Unread 21-01-2015, 22:22
Darkseer54's Avatar
AKA: Zach Kaplan
Sorry, I had misinterpreted your issue . Are you sure that you are properly deploying? Is can you enable teleop? Have you tried to drive a motor?
Unread 22-01-2015, 19:10
FRC #0008
@JefferMC We have robot communications and robot code working as shown on the Driver Station with green lights.
@DarkSeer54
We are properly deploying, but are not sure about teleop being enabled, as we have print statements in teleopInit() and teleopPeriodic() that are not printing.
We look for our printed statements in the NetConsole, which has been working fine.
Unread 22-01-2015, 23:23
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Code in the teleop*() methods won't get executed until you've enabled your robot in telop mode through the driver station.
The robotInit() and disabled*() methods get executed prior to enabling the robot.
http://team2168.org
Unread 23-01-2015, 01:32
Make sure you are using the correct case. teleopInit/Periodic won't ever get called. TeleopInit/Periodic is correct.
What statements do come out in NetConsole?
Unread 24-01-2015, 12:02
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
If you are actually looking at the Net console as in past years you will not see anything. You need to look at the Rio log in eclipse.
Is the print statement the first line in the RobotInit function?
Unread 24-01-2015, 13:06
Netconsole still works. rioLog uses the same protocol.
