Go to Post Archimedes brings all the bots to the yard! - looneylin [more]
Unread 21-01-2015, 22:03
Mineboy2300's Avatar
Mineboy2300 Mineboy2300 is offline
Drive Captain
AKA: Benjamin Louttit
FRC #2637 (Phantom Catz)
Team Role: Driver
Mineboy2300 is an unknown quantity at this point
Gear Ratio For Mecanum
We are Building our Mecanum Drive for this years robot and are wondering if anyone knows what a good gear ratio would be if we are powering 4 wheels with 1 cim each. We want to be able to go across the bumps with our ~120 pound robot plus 6 totes. Thanks
Unread 21-01-2015, 22:35
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Re: Gear Ratio For Mecanum
It depends on your wheel size.
The recommendation I heard from buildblitz was to aim for ~10ft per sec. This pushes the gear ratio tradeoff more towards torque (controllability) and less towards top speed.
Unread 21-01-2015, 22:38
zachrobo1's Avatar
zachrobo1 zachrobo1 is offline
AKA: Zach Cloud
FRC #1002 (The CircuitRunners)
zachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of light
We used VexPro's single reduction gearbox (11:72) with another 1:2 reduction via belt to drive 8 inch mecanum wheels. It puts us around 11fps, which is great for our applications.
Team 1002 - Website - Facebook - Twitter - Youtube
Unread 21-01-2015, 22:39
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
If it's single-speed it depends on the driver mostly. Can they properly position your drive, and quickly? I would recommend making a system with a number of selectable gear ratios so you can decide on the fly. A vex clamping gearbox with a secondary sprocket reduction to the wheels could work well.
Anything above fps can technically work, but I think we're going with something like 14fps.
The robot + totes is only 180lbs, and you're not pushing other robots (hopefully).
Unread 21-01-2015, 23:31
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
You should be able to drive the hump as long as you have enough ground clearance and any two-stage gear ratio. The lower you gear (that is, the higher the number opposite the :1), the more capability for acceleration, push, and fine control. The higher you gear, the faster you can go when you reach full speed. Maximum speed for a typical 80% efficient drive train is 18.5 fps * the wheel diameter in inches / gear ratio. To get 10fps (as recommended below) with 4" wheels (whether mecanum or traction) you'd want a target gear ratio of about 7.4:1. With 6" wheels, it's about 11.1, and with 8", about 14.8:1. 10fps is rather slow for most of the FRC games, but with high-speed robots more likely to knock stacks over than build them up, this is certainly a defensible number.
Unread 22-01-2015, 00:10
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I calculated it:
top speed = efficiency * free-speed-of-shaft * wheel-radius
For a 1 inch diameter wheel (1/2" radius), a CIM on a 1:1 gearbox, and an 80% efficient drive train, and converting all the units:
0.8 * 5310 rpm * (2 * pi radians/rev) * 0.5in (radius) / (60 sec/min * 12 in/ft) = 18.5 fps.
Unread 22-01-2015, 00:14
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Take a look at this Build Blitz resource on Mecanum Drive Options. It gives you some good example ratios, as well as the calculations behind them.
http://www.buildblitz.com/mecanum-drivetrain-options/
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 22-01-2015, 00:22
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
We've elected to go for 72:12 from VEXPro's clamping gearboxes, with an additional 42:24 belt reduction, for an overall JVN speed of 10.72 ft/s on 6" wheels.
We've also purchased 11t cim pinion gears in the event that we find find that we've geared too fast, which would reduce our JVN speed to 9.83 ft/s.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
