Go to Post They had a well made scouting form on the bottom was a check box with nothing next to it, when asked what the box was for they said. "Oh thats the jerk box" Since then one of our team goals is "Stay out of the jerk box" - Gary Stearns [more]
Unread 21-01-2015, 09:03
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Autonomous Help
That looks good. Let me know if there is anything else.
Unread 21-01-2015, 09:10
curtis0gj curtis0gj is offline
FRC #5033 (Beavertronics)
Rookie Year: 2015
curtis0gj will become famous soon enough
Re: Autonomous Help
Thanks a bunch I will test this tonight and get back to you if I need any more help. Thanks!
Unread 21-01-2015, 17:42
Rookie Year: 2015
Re: Autonomous Help
Just tested the program and the robot executed the turn and went on into the straight drive however it did not stop and I also noticed that I was not getting a distance value on my smart dashboard. Tomorrow we are going to check the encoder with a multimeter and see if we get any voltages.
Unread 21-01-2015, 17:44
Re: Autonomous Help
What kind of voltages are you expecting to get?
Unread 21-01-2015, 17:52
Rookie Year: 2015
Re: Autonomous Help
No Idea my mentor thought we would get some answers doing that. I'm just concerned the encoder may be broken.
Unread 21-01-2015, 18:50
Rookie Year: 2015
Re: Autonomous Help
I also think it could be the encoder.setDistanceperpulse(); because I don't know what it needs to be set at.
Unread 22-01-2015, 06:42
Rookie Year: 2015
Re: Autonomous Help
Should the encoder be plugged into DIO or analog?
Unread 22-01-2015, 09:47
Flywheel Police
Re: Autonomous Help
It needs to be plugged into DIO. What kind of encoder are you working with?
Unread 22-01-2015, 09:53
Rookie Year: 2015
Re: Autonomous Help
[quote=notmattlythgoe;1432076]It needs to be plugged into DIO. What kind of encoder are you working with?[/QUOTEh
http://www.andymark.com/product-p/am-0180.htm
US Digital Encoder E4P-250-250-N-S-D-D-B
Unread 22-01-2015, 09:56
Flywheel Police
Re: Autonomous Help
[quote=curtis0gj;1432078]
This will need placed into 2 DIO ports.
Unread 22-01-2015, 09:59
Re: Autonomous Help
Did you try this yet?
Unread 22-01-2015, 10:04
Rookie Year: 2015
Re: Autonomous Help
[quote=notmattlythgoe;1432080]
Alright I have it in two of the DIO ports. However it is possible that we soldered it wrong or maybe have the cables plugged into the DIO backwards.
Unread 22-01-2015, 10:11
Rookie Year: 2015
Re: Autonomous Help
We are going to do that tonight and I think it's to check the solder we did.
Unread 22-01-2015, 10:14
Rookie Year: 2015
Re: Autonomous Help
This is the wiring we followed does it look correct?http://frc-labs.com/wp-content/uploa...03/encoder.png
Unread 22-01-2015, 10:18
Re: Autonomous Help
The E4P-250-250-N-S-D-D-B has single-ended outputs, and according to the datasheet you should get a square wave on each of the 2 output signal channels (A & B).
As you manually rotate the encoder shaft (very very slowly), you should see the voltage going from ~5V to ~0.4V on each channel.
