Thread Tools |
Rating:
Display Modes |
Re: pic: The BoltBots Team 5040 Robot week 3 in the build !
CIM, not SIM.
Looks good! Did you use a license plate for the corner gussets? |
It is a street sign that was found in a ditch complete with shot gun blast and bullet holes in it . The students just thought it would be cool to build from as much recycled material as possible.
The lifting frame is made from Tele-Power poles that were acquired from dumpster diving at a office remodeling project . The 80/20 was surplus from a local college and other supporting parts are window frame extrusions found dumped in a vacant lot next to my house.
If you are still testing winch motors my team has had much success with a CIM motor attached to a gearbox from a Dewalt drill. There is a whitepaper out there somewhere on it. I believe Dr. Joseph Johnson(one of our old mentors) made it but I'm not entirely sure. We used this set up during breakaway to lift our entire robot off the ground with no trouble at all.
http://www.chiefdelphi.com/media/papers/1592 |
For our elevator we are using a CIM with a 25:1 Vexpro VersaPlanetary gearbox driving sprocket and chain. The sprocket's pitch diameter is 1.79 inches. With a 40 lb load we can go up at 1.3 feet /sec measured. Our Pid controller puts out 15 % motor power to maintain the 40 lb load at set point. With 20lb load there is no motor output at setpoint with the talon set to brake.
#7
Very good ideas and looks like your team has done a lot of research on the gear box design . Our team is composed of 95% new kids this year and they need all the advise can get. They thought about chain drive but are leaning to using a wire cable and winch design for the lift. |
#8
