Go to Post You mean to tell me there's a weight limit this year?!?!?!!? - Carlo [more]
Unread 21-01-2015, 09:03
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Autonomous Help
That looks good. Let me know if there is anything else.
Unread 21-01-2015, 09:10
curtis0gj curtis0gj is offline
FRC #5033 (Beavertronics)
Rookie Year: 2015
curtis0gj will become famous soon enough
Re: Autonomous Help
Thanks a bunch I will test this tonight and get back to you if I need any more help. Thanks!
Unread 21-01-2015, 17:42
Rookie Year: 2015
Re: Autonomous Help
Just tested the program and the robot executed the turn and went on into the straight drive however it did not stop and I also noticed that I was not getting a distance value on my smart dashboard. Tomorrow we are going to check the encoder with a multimeter and see if we get any voltages.
Unread 21-01-2015, 17:44
Re: Autonomous Help
What kind of voltages are you expecting to get?
Unread 21-01-2015, 17:52
Rookie Year: 2015
Re: Autonomous Help
No Idea my mentor thought we would get some answers doing that. I'm just concerned the encoder may be broken.
Unread 21-01-2015, 18:50
Rookie Year: 2015
Re: Autonomous Help
I also think it could be the encoder.setDistanceperpulse(); because I don't know what it needs to be set at.
Unread 22-01-2015, 06:42
Rookie Year: 2015
Re: Autonomous Help
Should the encoder be plugged into DIO or analog?
Unread 22-01-2015, 09:47
Flywheel Police
Re: Autonomous Help
It needs to be plugged into DIO. What kind of encoder are you working with?
Unread 22-01-2015, 09:53
Rookie Year: 2015
Re: Autonomous Help
[quote=notmattlythgoe;1432076]It needs to be plugged into DIO. What kind of encoder are you working with?[/QUOTEh
http://www.andymark.com/product-p/am-0180.htm
US Digital Encoder E4P-250-250-N-S-D-D-B
Unread 22-01-2015, 09:56
Flywheel Police
Re: Autonomous Help
[quote=curtis0gj;1432078]
This will need placed into 2 DIO ports.
Unread 22-01-2015, 09:59
Re: Autonomous Help
Did you try this yet?
Unread 22-01-2015, 10:04
Rookie Year: 2015
Re: Autonomous Help
[quote=notmattlythgoe;1432080]
Alright I have it in two of the DIO ports. However it is possible that we soldered it wrong or maybe have the cables plugged into the DIO backwards.
Unread 22-01-2015, 10:11
Rookie Year: 2015
Re: Autonomous Help
We are going to do that tonight and I think it's to check the solder we did.
Unread 22-01-2015, 10:14
Rookie Year: 2015
Re: Autonomous Help
This is the wiring we followed does it look correct?http://frc-labs.com/wp-content/uploa...03/encoder.png
Unread 22-01-2015, 10:18
Re: Autonomous Help
The E4P-250-250-N-S-D-D-B has single-ended outputs, and according to the datasheet you should get a square wave on each of the 2 output signal channels (A & B).
As you manually rotate the encoder shaft (very very slowly), you should see the voltage going from ~5V to ~0.4V on each channel.
