Go to Post Good tooling doesn't cost money, it makes money (and prevents doctor visits). - travis [more]
  #31   Spotlight this post!
Unread 22-01-2015, 10:23
curtis0gj curtis0gj is offline
FRC #5033 (Beavertronics)
Rookie Year: 2015
curtis0gj will become famous soon enough
Re: Autonomous Help
The E4P-250-250-N-S-D-D-B has single-ended outputs, and according to the datasheet you should get a square wave on each of the 2 output signal channels (A & B).
As you manually rotate the encoder shaft (very very slowly), you should see the voltage going from ~5V to ~0.4V on each channel.
Alright I will give this a shot I'm not the best with electrical stuff but this sounds doable.
  #32   Spotlight this post!
Unread 22-01-2015, 16:23
Rookie Year: 2015
Re: Autonomous Help
Okay we testing out the encoder with our multimeter the volts seem good we got .4 to 5v however I am still not getting a number on my smartdash and I am not stopping. Here's the whole program.
package org.usfirst.frc.team5033.robot;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.Gyro;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.CounterBase.EncodingType;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
public class Robot extends IterativeRobot {
	RobotDrive robot;
    Joystick stick;
    Encoder encoder;
    Gyro gyro1;
    static final double Kp = 0.05;
    public void robotInit() {
    	 robot = new RobotDrive(0, 1);
         stick = new Joystick(0);
         gyro1 = new Gyro(0);
         gyro1.reset();
         gyro1.initGyro();
         Encoder encoder = new Encoder(0, 1, false, EncodingType.k4X);
         encoder.setDistancePerPulse(0.001);
         encoder.getDistance();
    public void autonomousPeriodic() {
    	gyro1.reset();
    	while(isAutonomous() && isEnabled())  {
    		double angle = gyro1.getAngle();
    		double distance = encoder.getDistance();
    		SmartDashboard.putNumber("Angle", angle);
    		SmartDashboard.putNumber("Distance", distance);
    		robot.drive(-0.25, 1);
    		if(angle > 150) {
    			robot.drive(0,0);
    			gyro1.reset();
    			encoder.reset();
    			Timer.delay(0.5);
    			break;
    			Timer.delay(0.1);
				while (isAutonomous() && isEnabled()) {
						double angle2 = gyro1.getAngle();
						double distance2 = encoder.getDistance();
						SmartDashboard.putNumber("Distance", distance2);
						robot.drive(-0.20, -angle2 * Kp);
						if(encoder.getDistance() < 10)  {
							robot.drive(0,0);
							break;
						Timer.delay(0.1);
    public void teleopPeriodic() {
    	while (isOperatorControl() && isEnabled()) {
        	SmartDashboard.putNumber("angle", gyro1.getAngle());
        	stick.getThrottle();
            robot.arcadeDrive(stick.getY(), -stick.getX(), false);
            Timer.delay(0.1);
    public void testPeriodic() {
  #33   Spotlight this post!
Unread 22-01-2015, 17:25
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Autonomous Help
	RobotDrive robot;
    Joystick stick;
    Encoder encoder;
    Gyro gyro1;
         gyro1.reset();
         gyro1.initGyro();
    	gyro1.reset();
    		if(angle > 150) {
    			robot.drive(0,0);
    			gyro1.reset();
    			encoder.reset();
    			Timer.delay(0.5);
    			break;
    			Timer.delay(0.1);
							robot.drive(0,0);
							break;
						Timer.delay(0.1);
            Timer.delay(0.1);
Try setting the distance per pulse to 1.
  #34   Spotlight this post!
Unread 22-01-2015, 17:57
Rookie Year: 2015
Re: Autonomous Help
I can try this tomorrow but do I need to maybe setup the dash board to display the distance or will it just appear?
  #35   Spotlight this post!
Unread 22-01-2015, 18:01
Flywheel Police
Re: Autonomous Help
It will just appear. You are bringing up the java dashboard not the default one right?
  #36   Spotlight this post!
Unread 22-01-2015, 18:08
Rookie Year: 2015
Re: Autonomous Help
Yeah what I do is switch my ds setting from remote to java and this opens my smart dashboard that I have setup with a camera and the angle reading.
  #37   Spotlight this post!
Unread 23-01-2015, 09:44
Rookie Year: 2015
Re: Autonomous Help
Is there a better way to open smart dashboard for java?
  #38   Spotlight this post!
Unread 23-01-2015, 09:47
Flywheel Police
Re: Autonomous Help
That's the way we do it too. There a way to set the default to be the SmartDashboard, but I'd have to look into how to do that again.
  #39   Spotlight this post!
Unread 23-01-2015, 09:49
Rookie Year: 2015
Re: Autonomous Help
So setting the pulse to 1 does not work is there anything else I can try?
  #40   Spotlight this post!
Unread 23-01-2015, 09:54
Flywheel Police
Re: Autonomous Help
Try doing encoder.start() in robotInit() after you declare the encoder. This method used to exist in last year's API but I don't see it in the documentation right now.
  #41   Spotlight this post!
Unread 23-01-2015, 09:57
Rookie Year: 2015
Re: Autonomous Help
Yeah I have been encoder
start(); but it just gave me errors I guess there's no such thing this year.
  #42   Spotlight this post!
Unread 23-01-2015, 09:59
Flywheel Police
Re: Autonomous Help
Can you try changing your getDistance() to just get().
  #43   Spotlight this post!
Unread 23-01-2015, 10:01
Rookie Year: 2015
Re: Autonomous Help
In the init?
  #44   Spotlight this post!
Unread 23-01-2015, 10:03
Flywheel Police
Re: Autonomous Help
double distance2 = encoder.get();
  #45   Spotlight this post!
Unread 23-01-2015, 10:07
Rookie Year: 2015
Re: Autonomous Help
How about double distance = encoder.get(); as well?
