Go to Post Maybe we won't get any motors at all! Rotary Pneumatics, here we come! - Tom Bottiglieri [more]
Unread 22-01-2015, 11:23
The_Waffleing's Avatar
The_Waffleing The_Waffleing is offline
The Horse Shaman
AKA: Mitchel
FRC #0753 (The High Desert Droids)
The_Waffleing is an unknown quantity at this point
Exponential Motor Acceleration
I'm trying to create a motor control that will accelerate and decelerate exponentially and of course I can solve that mathematically but am having troubles in taking that idea and inputting it into Labview. I can do it in just about any other text based language but I can't seem to figure it out in Labview. Any thoughts?
Unread 22-01-2015, 12:57
Re: Exponential Motor Acceleration
What does "accelerate and decelerate exponentially" mean? I know what the individual words mean, but putting them together like that makes me imagine a wheel turning faster at an ever-increasing rate, quickly reaching the point of rapid catastrophic disassembly.
If you can write what you want in a C-like language, I can show you how to translate that to LabVIEW. It could even be as easy as writing it verbatim in a formula node.
Last edited by Alan Anderson : 22-01-2015 at 13:31. Reason: darn autocorrect -- I mean, corrected a mistyped word
Unread 22-01-2015, 13:18
If what you are looking for are functions for log and exp, they are in Mathematics >> Elementary Functions, right next to trig and hyperbolic. As Alan said, many of these are supported in the formula node too, using a C subset syntax.
Greg McKaskle
Unread 22-01-2015, 13:33
Perhaps you are referring to contouring the joystick output exponentially?
Here is a joystick exponential mapping function which maps a Joystick value between 0 and +1, inclusive, to an adjusted value in the same range:
Joystick_adjusted = (1-bJoystick)/(1-b);
For range -1 to 0, use this:
Joystick_adjusted = -(1-b-Joystick)/(1-b);
b≠1 is a tuning parameter.
Example graph below with b=10
Unread 22-01-2015, 14:06
The Horse Shaman
AKA: Mitchel
I chuckled with your ending bit there. What I'm trying to get at is if you fully throttle the joysticks forward instead of a sudden increase from 0 to 1 in a fraction of a second have it gradually increase over the course of 2 seconds or something of that nature. Ether I believe has answered my question however I haven't tried it yet so I will report back later if it's right.
Unread 22-01-2015, 14:16
What I posted is a joystick mapping; it won't do what you just described above.
What you want is some sort of rate limiter.
http://thinktank.wpi.edu/article/140 (look for the section titled Slew Rate – How do I limit the rate of change?)
http://www.chiefdelphi.com/forums/sh...23&postcount=2
Unread 22-01-2015, 14:36
What you want is called "rate limiting". Searching with that keyword phrase will give you lots of useful information. Here is one document that ought to help.
Unread 22-01-2015, 15:25
The Horse Shaman
AKA: Mitchel
Talking Re: Exponential Motor Acceleration
Okay got it figured out now. Thanks a bunch for the input.
