Go to Post 254 bends CIM shafts every now and then in the drivetrain. I didn't believe it was possible until I saw it myself. - AustinSchuh [more]
Unread 12-01-2015, 09:50
frcteam2501's Avatar
frcteam2501 frcteam2501 is offline
Kyle Ronsberg
AKA: Kyle Ronsberg
FRC #6056 (Brotherhood of Steel)
frcteam2501 is an unknown quantity at this point
Eclipse fails build project
While using Eclipse to build our C++ projects on the lab computer the console outputs
Cannot run program "make": Launching failed
Error: Program "make" not found in PATH
PATH=[C:/Program Files/Java/jre1.8.0_25/bin/server;C:/Program Files/Java/jre1.8.0_25/bin;C:/Program Files/Java/jre1.8.0_25/lib/amd64;C:\frc\bin;C:\Program Files\Java\jre1.8.0_25\bin;C:\Program Files (x86)\Git\cmd;C:\Program Files (x86)\Git\bin;C:\Program Files\Java\jre7\bin;C:\Program Files\eclipse;]
Does anyone know what I have to add to our PATH to make it work?
Team: 2501
Unread 12-01-2015, 09:54
ThatGuyAdam's Avatar
ThatGuyAdam ThatGuyAdam is offline
Buzzword Master
FRC #4121 (Viking Robotics)
ThatGuyAdam is a jewel in the roughThatGuyAdam is a jewel in the roughThatGuyAdam is a jewel in the roughThatGuyAdam is a jewel in the rough
Re: Eclipse fails build project
See this post. You need to add the path the FRC toolkit path to eclipse.
Did you install the toolchain? http://wpilib.screenstepslive.com/s/...eclipse-c-java
you'll need to restart eclipse after installing it.
Unread 21-01-2015, 18:07
bborah7390 bborah7390 is offline
FRC #4941 (RoboBibb)
bborah7390 is an unknown quantity at this point
I am still having this issue in Eclipse. I have appended the environment variable with FRC and the folder the toolchain was installed in.
Is anyone still having this issues or know how to fix this issue?
PATH=[C:\Program Files\eclipse-cpp-luna-SR1a-win32-x86_64\eclipse;C:/Program Files/Java/jre1.8.0_25/bin/server;C:/Program Files/Java/jre1.8.0_25/bin;C:/Program Files/Java/jre1.8.0_25/lib/amd64;C:\ProgramData\Oracle\Java\javapath;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Program Files\Dell\DW WLAN Card;;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Dell\Dell Data Protection\Access\Advanced\Wave\Gemalto\Access Client\v5\;C:\Program Files (x86)\Security Innovation\SI TSS\bin\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\;C:\Program Files\IVI Foundation\VISA\Win64\Bin\;C:\frc\bin]
Unread 21-01-2015, 18:56
Are you trying to build one of the FRC projects? If so, double check to makes sure that Debug is the selected build configuration.
Unread 22-01-2015, 08:47
I will look this afternoon and let you know but I think I have tried in both debug and release modes. Still have the same results for both scenarios.
Unread 22-01-2015, 12:15
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Just a gut feel here - if you manually change your path (right click on my computer...properties...Environment...doing this from memory...) When you find the path that looks similar to the path you reported above, put
C:\frc\bin;
at the BEGINNING of the path and see if that solves it.
My theory here is that your path is VERY long and possibly Eclipse is having troubles with it somehow - or there is a character in the path which is making Eclipse barf and so it's never ultimately getting to the END of the path which does indeed show C:\frc\bin
Very interested to know the final fix if it's not this stab in the dark.
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 23-01-2015, 08:20
I tried both debug and release modes yesterday afternoon with no luck. I also tried your suggestion bob with no luck as well. I have a friend coming to look at it Saturday will let you know my results.
Unread 30-01-2015, 09:32
FRC2501's Avatar
FRC2501 FRC2501 is offline
FRC #2501 (Bionic Poalrs)
FRC2501 is an unknown quantity at this point
So far editing the normal PATH and using eclipse to append to the PATH has worked (idk if it was that or the total reinstall of Eclipse, build tools and the NI software)
