Go to Post Now, most of the replies are very tactful when they are questioning a teams' design... but some are simply stupid. Keep your heads. - Andy Baker [more]
Unread 22-01-2015, 14:06
The_Waffleing's Avatar
The_Waffleing The_Waffleing is offline
The Horse Shaman
AKA: Mitchel
FRC #0753 (The High Desert Droids)
The_Waffleing is an unknown quantity at this point
Re: Exponential Motor Acceleration
Originally Posted by The_Waffleing View Post
I'm trying to create a motor control that will accelerate and decelerate exponentially and of course I can solve that mathematically but am having troubles in taking that idea and inputting it into Labview. I can do it in just about any other text based language but I can't seem to figure it out in Labview. Any thoughts?
I chuckled with your ending bit there. What I'm trying to get at is if you fully throttle the joysticks forward instead of a sudden increase from 0 to 1 in a fraction of a second have it gradually increase over the course of 2 seconds or something of that nature. Ether I believe has answered my question however I haven't tried it yet so I will report back later if it's right.
Unread 22-01-2015, 14:16
What I posted is a joystick mapping; it won't do what you just described above.
What you want is some sort of rate limiter.
http://thinktank.wpi.edu/article/140 (look for the section titled Slew Rate – How do I limit the rate of change?)
http://www.chiefdelphi.com/forums/sh...23&postcount=2
Unread 22-01-2015, 14:36
What you want is called "rate limiting". Searching with that keyword phrase will give you lots of useful information. Here is one document that ought to help.
Unread 22-01-2015, 15:25
The Horse Shaman
AKA: Mitchel
Talking Re: Exponential Motor Acceleration
Okay got it figured out now. Thanks a bunch for the input.
