Thread Tools |
Rating:
Display Modes |
Re: pic: 6 week swerve
However, consider this: you can make the gearing change, the drive is sluggish and does not perform well when you demo it, but by gosh it never gets hung up on the ramp (which is the whole reason to change gearing, right?) Or, you can leave in a more robust gear ratio, and show that the drive accelerates well, is very controllable, and behaves nicely; and though the gears might contact the playing field under certain rare circumstances, you can solve that problem by making any of the changes mentioned in this thread. If you're going to argue for swerve drive, which of those situations gives you a firmer position to argue from? Edit: In the spirit of full disclosure, my team is setting up a chassis with a free speed of around 14 ft/s. We made this decision based upon easily available gear ratios, easily available wheels, and ability to neatly integrate it into our chassis. We are, however, planning on using 4 CIMs and 4 mini-CIMs, which will help offset the losses in acceleration and low-speed control at the expense of weight. Last edited by JamesCH95 : 22-01-2015 at 15:42. |
In 2012 we optimized the drive base design for bridge balancing. We knew we needed very fine control and designed the drive base around that. Teams all year wondered how our driver could balance with nearly any other robot so quickly and efficiently. The real key was the fine control of the drive base. If our driver wanted to move the robot forward a half-inch to finish the balance, she could easily do that - no problem. Our gearing in low gear that year was 2.35fps (after efficiency losses). The real benefit of the low gearing wasn't the power in low gear (although that didn't hurt) but was the fine control for bridge balancing. Does stacking totes seem like a high-precision task? |
I'm back on a computer and actually have some time so hopefully I can write a response that will make me seem less willfully ignorant
First of, the change in gearing is an admittedly quick and dirty fix, but what I believe to be the best fix just to get some pods printed up and working together. We are 3d printing the first iteration of the pods in the next few nights so that we can have something together and working so our programmer has the maximum amount of time to work on getting the pods working together nicely and field oriented control working nicely. The gearing change is by no means a final fix which is something I something I don't think I ever mentioned (serious mistake on my part), it is just a quick fix to get the test bed together and running. What i'm leaning towards as a final fix is a cim face mounted to the lower plate with a cim gear going to a gear on some .5 hex shaft. That shaft will have the pulley that was previously on the cim with the same gear reduction. If I do this right that means the wheel pod reduction could actually end up being something like 50:30 (as opposed to the previous 30:50) which should leave more than enough ramp clearance for the wheel gear. The testing we're going to do tonight is only to see if last years robot (roughly 15 fps) with motor speed limited will give us fine enough control for our collector (In my mind our robot design is split into collector and indexer, collector is the only part that needs fine control). If it is it leaves the current quick and dirty gear change fix as a semi viable option if for some reason everything goes to crap. All of the downsides (motor speed being limited as opposed to proper gearing, barely scraping by on ramp clearance, etc.) will all be taken into account in the final decision matrix that decides if our swerve is actually worth it or if we should throw in the tank drive. |
updates http://imgur.com/a/MYNGL
