Go to Post The main use of Chiefdelphi is self expression of what FIRST means to you. - Koko Ed [more]
  #32   Spotlight this post!
Unread 22-01-2015, 16:23
curtis0gj curtis0gj is offline
FRC #5033 (Beavertronics)
Rookie Year: 2015
curtis0gj will become famous soon enough
Re: Autonomous Help
Okay we testing out the encoder with our multimeter the volts seem good we got .4 to 5v however I am still not getting a number on my smartdash and I am not stopping. Here's the whole program.
package org.usfirst.frc.team5033.robot;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.Gyro;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.CounterBase.EncodingType;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
public class Robot extends IterativeRobot {
	RobotDrive robot;
    Joystick stick;
    Encoder encoder;
    Gyro gyro1;
    static final double Kp = 0.05;
    public void robotInit() {
    	 robot = new RobotDrive(0, 1);
         stick = new Joystick(0);
         gyro1 = new Gyro(0);
         gyro1.reset();
         gyro1.initGyro();
         Encoder encoder = new Encoder(0, 1, false, EncodingType.k4X);
         encoder.setDistancePerPulse(0.001);
         encoder.getDistance();
    public void autonomousPeriodic() {
    	gyro1.reset();
    	while(isAutonomous() && isEnabled())  {
    		double angle = gyro1.getAngle();
    		double distance = encoder.getDistance();
    		SmartDashboard.putNumber("Angle", angle);
    		SmartDashboard.putNumber("Distance", distance);
    		robot.drive(-0.25, 1);
    		if(angle > 150) {
    			robot.drive(0,0);
    			gyro1.reset();
    			encoder.reset();
    			Timer.delay(0.5);
    			break;
    			Timer.delay(0.1);
				while (isAutonomous() && isEnabled()) {
						double angle2 = gyro1.getAngle();
						double distance2 = encoder.getDistance();
						SmartDashboard.putNumber("Distance", distance2);
						robot.drive(-0.20, -angle2 * Kp);
						if(encoder.getDistance() < 10)  {
							robot.drive(0,0);
							break;
						Timer.delay(0.1);
    public void teleopPeriodic() {
    	while (isOperatorControl() && isEnabled()) {
        	SmartDashboard.putNumber("angle", gyro1.getAngle());
        	stick.getThrottle();
            robot.arcadeDrive(stick.getY(), -stick.getX(), false);
            Timer.delay(0.1);
    public void testPeriodic() {
