Go to Post ROBUST, ROBUST and ROBUST if you want to win - dan 322 [more]
Thread Tools Rating: Thread Rating: 20 votes, 5.00 average. Display Modes
Unread 19-01-2015, 17:26
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
Encoders for WCP SS Gearbox
What are teams using for encoders on the WCP SS gearbox? I couldn't find anything on their website and nothing came up with a search here.
Unread 20-01-2015, 12:37
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Re: Encoders for WCP SS Gearbox
If you look at the back plate of the gearbox on page 3 here, you can see two holes situated around where the back of the output shaft is. Also on that output shaft, there is a smaller 1/4" hole in the shaft (it may be tapped to 1/4-20, i don't remember). You can use the hole in the shaft to insert an encoder shaft, and use the holes on the gearbox plate to create a custom mount for your encoder. Grayhill encoders are pretty good encoders that are easy to mount and use.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 20-01-2015, 12:56
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Originally Posted by Anupam Goli View Post
Also on that output shaft, there is a smaller 1/4" hole in the shaft (it may be tapped to 1/4-20, i don't remember). You can use the hole in the shaft to insert an encoder shaft, and use the holes on the gearbox plate to create a custom mount for your encoder. Grayhill encoders are pretty good encounters that are easy to mount and use.
The SS output shaft hole on the end of the axle (where the wheel goes) is tapped. The hole on the other side (where the slip ring goes) is 1/4" but is not tapped.
+1 on the Greyhill encoder. We put the greyhill encoder into the untapped 1/4" hole, connected the wire and then ziptied the wire to the gearbox plate close to the output shaft bearing.
Unread 20-01-2015, 13:08
Andrew Lawrence
Posts: n/a
On a wcd (the drive the SS was designed around *though is not limited to*), it is a common practice to attach the encoders to the outer wheel shafts as seen in this picture. Encoders are pressed into shaft ends and prevented from rotating with the shaft by tying down the wires to the bellypan with zip ties.
Unread 20-01-2015, 15:09
Shu Shu is offline
FRC #2137 (TORC)
Thanks for the responses. It looks like I have several options then. Which Greyhill encoder do you recommend?
Unread 20-01-2015, 15:10
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
Most people will recommend the Grayhill 63R encoders. We will be using these for our (custom) gearboxes this year.
Unread 22-01-2015, 16:47
Underdog_19 Underdog_19 is offline
FRC #4909 (Bionics)
Underdog_19 has a spectacular aura aboutUnderdog_19 has a spectacular aura about
We're looking at using this encoder with a Toughbox Nano. Any ideas on how to mount it?
Unread 22-01-2015, 16:51
FRC #1836 (MilkenKnights)
On the SS encoders can be attached to the center wheel because there are no pneumatic actuators for shifting
