Go to Post When you are at the regional no one cares if you are a rookie. You are a part of the family. - scitecteach [more]
Unread 19-01-2015, 21:17
REDBARON's Avatar
REDBARON REDBARON is offline
AKA: Jack
FRC #3556 (Get Smart)
Rookie Year: 2015
REDBARON is an unknown quantity at this point
Wiring encoders with roborio
Our team has decided to use an encoder this year, we are having difficulties because the ports are spaced out, whereas with the c-Rio there was no spacing, the only option we have seen thus far is to use a 4-pin header, which we have none of, have any other teams faced a similar problem and have any other solutions? All help is appreciated.
Unread 19-01-2015, 21:44
Joe Derrick's Avatar
Joe Derrick Joe Derrick is offline
Mentor - Programming
FRC #0319
Joe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of light
Re: Wiring encoders with roborio
we have used the female-female single pin connectors
like these
however if you are going to use the talon xrs I guess you have
to use vex robotics talon data cables "ribbon" unless the breakout boards get re-stocked and/or you can design your own
2010-2017 Mentor Team 319
2012 - Rockwell Automation Award Winner
2014 - Xerox Creativity in Engineering Winner, Archimedes Division
2015 - Rockwell Automation and Gracious Proffesionalism Winner, Tesla Division
2016 - North Shore and UNH District Event Winner, Carson Division
http://www.frc319.com
Unread 19-01-2015, 22:22
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Could you post a picture at your convenience? It sounds to me like you are trying to place the connector in the wrong orientation on the roboRIO. You may also have a 4 pin encoder and are wondering how to connect it to a 3 pin channel on the roboRIO? Not totally sure. A follow up with more information would be appreciated and would make it easier for others to better assist you.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 20-01-2015, 18:19
REDBARON's Avatar
AKA: Jack
Rookie Year: 2015
We're ordering 4-pin connectors, we think this should resolve the problem.
Thank you for all the help.
Unread 21-01-2015, 01:05
How will a 4 pin connector help? The DIO ports on the roboRIO are still only 3 pins each.
Unread 21-01-2015, 08:35
I think they mean to use the 4-pin connectors because they will stretch across the gap between adjacent sets of roboRIO .1 header pins. The two middle pin positions don't get used, just the two end ones.
Unread 22-01-2015, 19:02
AverageJoes4574 AverageJoes4574 is offline
FRC #4574
AverageJoes4574 is an unknown quantity at this point
Hi, sorry for the late reply, But you can wire the encoder through standard D I/O's on the RoboRio, but you will need to use 2 rows per encoder. 5v, gnd, and signal on the first row, and Signal 2 on the second D I/O port
