Go to Post I believe it is healthy to leave FIRST at some point and carry on with a well-rounded life (family, fun, school, & work). Focus your creative energy on developing your skills as a professional; then, come back to FIRST as a mentor later down the line. - Erin Rapacki [more]
Unread 12-01-2015, 18:54
SaltyPotato SaltyPotato is offline
FRC #4327
SaltyPotato is an unknown quantity at this point
Exclamation How to program H/Slide drive in labview?
We just decided to go with an slide drive train, with one motor in the middle and one motor at each corner of the chassis. Unfortunately we have no idea how to do that. Do we just bind the middle motor to the x-axis of one of the joysticks or...?
Side note we are using 2 Logitech joysticks for a tank drive setup.
Unread 12-01-2015, 19:00
Re: How to program H/Slide drive in labview?
What is the diameter and gear ratio for the center wheel?
Unread 12-01-2015, 19:19
FRC #4327
The diameter is 8 inches, and we haven't decided on a gear ratio, but does that have any influence on how you program the slide drive system?
Unread 12-01-2015, 19:45
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
You may want to consider using both of the X axes of your joysticks so you don't accidentally strafe. You can use the in range and coerce to accomplish this.
Unread 12-01-2015, 19:59
It has a tremendous influence on whether the slide will do what you want, and no amount of programming can fix it if it's not right.
http://www.chiefdelphi.com/forums/sh...28#post1426228
Unread 22-01-2015, 19:09
burde1jb's Avatar
burde1jb burde1jb is offline
FRC #4327 (Q Branch)
burde1jb will become famous soon enough
Thanks for all the help so far. FWIW, the gear ratio for the middle wheel will be through this gearbox (http://www.vexrobotics.com/vexpro/mo...es/wcp-ss.html) with a 12 tooth pinion and then a 60:14 second stage. This results in a 17.85:1 overall reduction.
That gives us a Free Speed of (according to the JVN calculator) 12.12 ft/s and an adjusted speed (at 120 lbs) of 9.82 ft/s. Speedy, we know.
We are powering the middle wheel with 3 MiniCims.
Any help with the code would be greatly appreciated. Thanks!
