Go to Post [You know you're proud to be a FIRSTer when...] You explain to someone how do do something, they go off and do it, come back and ask, "is this right?" and you say, "Yes." . - NorviewsVeteran [more]
Unread 22-01-2015, 21:38
N00bfirst N00bfirst is offline
FRC #4992
N00bfirst is an unknown quantity at this point
Dashboard not displaying messages
Our dashboard does not seem to display any message whatsoever when we try to run the robot code.
Can anybody please explain why such a thing is happening and how we can write to the dashboard?
This is just sample code to get the hang of the encoder average encoder value. Apologies for the terrible variable names.
However, it does not display a message even if I do something simple like trying to print a value onto the dashboard.
public void autonomousInit() {
autoLoopCounter = 0;
Encoder sampleEncoder = new Encoder(8, 9, false, Encoder.EncodingType.k2X);
sampleEncoder.setMaxPeriod(0.1);
sampleEncoder.setMinRate(10);
sampleEncoder.setDistancePerPulse(5);
sampleEncoder.setSamplesToAverage(7);
sampleEncoder.reset();
SmartDashboard.putNumber("hmm", 2);
double k = sampleEncoder.getRate();
boolean what = sampleEncoder.getStopped();
String huh = sampleEncoder.getSmartDashboardType();
while (k>10){
String k2 = Double.toString(k);
double distance = sampleEncoder.getDistance();
String distance1 = Double.toString(distance);
SmartDashboard.putNumber(k2, k);
SmartDashboard.putNumber(distance1, distance);
SmartDashboard.putBoolean(huh, what);
Unread 23-01-2015, 18:05
Quantum Byte's Avatar
Quantum Byte Quantum Byte is offline
Lead Programmer
AKA: Domenic
FRC #4776 (S.C.O.T.S. Bots)
Quantum Byte is an unknown quantity at this point
Re: Dashboard not displaying messages
Try putting all of the smartdashboard code you want to display:
while (k>10){
Into the autonomousPeriodic() method.
Unread 23-01-2015, 18:33
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
because your while loop's condition is k > 10.
You never set k to anything. Therefore, it will just runaway with the thread printing the same numbers to the dashboard (which will be 0 since the encoder was just reset)
you should move everything inside the "while" (plus the "double k = ...") to autonomousPeriodic. (don't use the person above mine's code, as it still suffers from the lack of setting 'k')
public void autonomousPeriodic(){
also
1) use more descriptive variable names (huh, what, k2, k are all very, very bad names) (I understand you used these to test, but these for testing isn't even acceptable. You're going to try to fix ur broken test code and u'll end up spending more time re-learning what the variables do than actually fixing the code)
2) don't instantiate ANYTHING (encoder... hint hint) in a function that can be run more than once as your code will error out
