Go to Post i feel lost without build season...like i should be somewhere working on something instead of sitting in my basement on my computer... - Wildcat [more]
Unread 01-22-2015, 11:53 PM
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 is on a distinguished road
Bundle Clusters by name
Does anyone know how to bundle clusters by name. I am trying to bundle all of the references. As you can see from the picture below if i bundle them they all have the same name. is there any way to change this http://i.imgur.com/HGUxR85.png?1
Unread 01-23-2015, 12:12 AM
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Bundle Clusters by name
When you bundle it, use a bundle by name instead, you will need to create a cluster constant with the data types & names that you want:
  1. Create a constant of the motor controller ref, and right click --> show label
  2. Double click the border to make it smaller
  3. Make the label you want, copy this constant x times, giving each a label
  4. Create a cluster constant, put the motor controller ref constants (in order) into the this cluster
  5. Use a bundle by name, feed the top terminal of the bundle by name with this cluster
Should look like this attached VI Snippet:
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 01-23-2015, 12:23 AM
Bpk9p4's Avatar
FRC #1756
thanks you for the fast response. This was very helpful
