Go to Post (Funding will be plentiful...) Where is this magical land? We can move our team there! - Tungrus [more]
  #46   Spotlight this post!
Unread 23-01-2015, 10:19
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Autonomous Help
Originally Posted by curtis0gj View Post
How about double distance = encoder.get(); as well?
That's fine, but since you aren't using distance anywhere it won't effect anything.
  #47   Spotlight this post!
Unread 23-01-2015, 10:25
curtis0gj curtis0gj is offline
FRC #5033 (Beavertronics)
Rookie Year: 2015
curtis0gj will become famous soon enough
Re: Autonomous Help
I will try all this later today I am hoping this will be my fix because it's been at least 4 days of trying to setup this encoder.
  #48   Spotlight this post!
Unread 23-01-2015, 10:26
Flywheel Police
Re: Autonomous Help
You did verify that the encoder is wired and plugged in correctly, including plugged into the correct ports?
I know its a basic question, but sometimes they need asked.
  #49   Spotlight this post!
Unread 23-01-2015, 10:29
Rookie Year: 2015
Re: Autonomous Help
+5 (orange) to the +5 pin of PWM connector #1
A (blue) to the signal pin on PWM connectore #1
Gnd (brown) to the ground pin of PWM connector #2
B (yellow) to the signal pin on PWM connector #2
Is what we are doing and we have the two PWM's into the DIO ports on the roboRIO.
  #50   Spotlight this post!
Unread 23-01-2015, 10:30
Rookie Year: 2015
Re: Autonomous Help
Using ports 0,1 aswell and have tried switching, flipping and inverting them.
  #51   Spotlight this post!
Flywheel Police
Re: Autonomous Help
Ether, can you comment on this? This doesn't seem right to me, shouldn't the ground be shared between both channels?
  #52   Spotlight this post!
Unread 23-01-2015, 10:33
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Autonomous Help
All of the ground pins should be connected internally.
  #53   Spotlight this post!
Unread 23-01-2015, 10:36
Rookie Year: 2015
Re: Autonomous Help
? What does this mean.
  #54   Spotlight this post!
Unread 23-01-2015, 11:17
Re: Autonomous Help
I think it's been that way for several years:
http://www.chiefdelphi.com/forums/sh...39&postcount=3
  #55   Spotlight this post!
Unread 23-01-2015, 11:19
Flywheel Police
Re: Autonomous Help
Cool, this is why I don't wire things.
  #56   Spotlight this post!
Unread 23-01-2015, 12:08
Rookie Year: 2015
Re: Autonomous Help
So wiring is good? Is it just a code thing or could the encoder be broken.
  #57   Spotlight this post!
Unread 23-01-2015, 12:09
Flywheel Police
Re: Autonomous Help
Have you verified electrically that the encoder is outputting information?
  #58   Spotlight this post!
Unread 23-01-2015, 12:14
Rookie Year: 2015
Re: Autonomous Help
Yep we get it gives us voltage readings from .4 to 5 v and we are getting a nice voltage feed on the 5v cable and ground so we do have electrical readings.
  #59   Spotlight this post!
Unread 23-01-2015, 12:15
Flywheel Police
Re: Autonomous Help
Can you explain your testing process?
  #60   Spotlight this post!
Unread 23-01-2015, 12:17
Rookie Year: 2015
Re: Autonomous Help
Sure! What we did was while running an autonomous movement code we were measuring dc voltage across the +5 and the common and we got a reading of +5. Then we ran it across the signal cables to the common and it was showing a square wave pretty much.
