Go to Post If this strategy backfires on any alliance that attempts it, they will have no one to blame but themselves. Be smart - know the risks before proceeding. - Travis Hoffman [more]
Unread 23-01-2015, 12:24
4373Henry's Avatar
4373Henry 4373Henry is offline
FRC #4373
4373Henry is an unknown quantity at this point
Java Command Based Layout - Using a Command Twice
Looking at examples of command based robots online, I noticed that most people tend to instantiate commands within the subsystem that uses them.
Our code has two drive related subsystems, one for the strafe motor and one for the tank drive motors. Both of these subsystems use the same command- Drive.
I have a feeling that a single command shouldn't be instantiated twice. Is the correct solution to use different commands? Or is it not proper convention to make these separate subsystems?
Unread 23-01-2015, 12:44
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Java Command Based Layout - Using a Command Twice
Can you link me to these ones you are seeing online?
Please take a look at our code from last year. We do as much as we can to make our commands reusable.
If you have any questions please don't hesitate to ask.
Unread 23-01-2015, 12:49
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Make the drive train subsystem have all the motors controlling the drive train. As for coding it I would suggest making your own drive code, if your going with the 5 wheel H drive its similar to arcade drive but assign the 5th or 3rd motor controller to some value like the x value of the joystick. Also you should have 1 default command for the drive train and that should be the one you use for teleop. Good question though!
Unread 23-01-2015, 13:11
I would tend to think that both parts of an H-drive should probably be part of the same subsystem. Is there ever a time that you would have two one command controlling tank drive and a different command controlling strafe?
A command can require multiple subsystems, which we've done before. I have not tried it, but I think that multiple subsystems should probably not add the same command as defaults. I think they would constantly interrupt each other.
