Go to Post Some call those dreams- others nightmares - Wayne C. [more]
Unread 23-01-2015, 12:46
Re: Problems with Driver Station
Originally Posted by Dave_4539 View Post
Nope... I followed directions from usfirst.org under frc...programming...driver station... so I will try those directions and see if that works... thanks!
You got to the ScreenSteps site okay, but it doesn't look like you went through the Getting Started with the 2015 Control System section. The Installing the FRC 2015 Update Suite (All Languages) is where it steps you through putting the software in the right place.
Unread 23-01-2015, 17:15
Dave_4539 Dave_4539 is offline
AKA: David
FRC #4539 (KAOTICRobotics)
Team Role: Driver
Dave_4539 is an unknown quantity at this point
Well I figured it out. It was just a National Instrument Update that hadn't been done. But now, when I log in as driver, the dashboard doesn't pop up like it has in the past. Its not a huge deal to us, but there is like two windows and the resolution is huge, and we can't see them both at one time. Is there some setting we can change in order to see everything?
Unread 23-01-2015, 17:18
Are you using the floating or docked window mode? In docked, it should scale to the resolution.
Unread 23-01-2015, 17:20
Is this on a Classmate or another laptop?
Did you set the task bar to Auto Hide and make more room on the screen?
Do the two windows have frames?
Unread 23-01-2015, 17:27
AKA: David
Team Role: Driver
Yeah, I auto-hid the task bar but it still doesn't snap to the correct resolution.
Unread 23-01-2015, 18:28
If you don't answer the questions we're asking, we can't do a good job of advising you further. To summarize what we still want to know:
Are you using the "floating" or "docked" window mode? If you don't know what that means, just tell us whether or not the windows have title bars.
Is this a Classmate laptop? If you don't know what that means, just tell us what brand of computer you are using.
Unread 23-01-2015, 21:19
AKA: David
Team Role: Driver
It is a classmate laptop, when i open the frc driver station icon on the desktop, it splits it into two windows, both of which are floating, and extending past the screen so I cant see all of it. I can only dock one of the windows to the top, making it impossible to see the other window...
Unread 23-01-2015, 22:09
Look for this on the Driver Station and click it.
Unread 24-01-2015, 19:38
Are the Driver Station windows too wide for the screen? That's a video driver issue on the E12 Classmate image. You need to be able to set the screen resolution to more than 800x600 in order for everything to fit.
I don't want to post a link to something if it's not going to help your problem. Let me know whether you're using an E12 and whether the screen width is the issue, and if so I'll point you to something which ought to help.
