Go to Post We like playing with power tools, stripping wire, or just stripping for alliance partners... - Amanda Morrison [more]
Unread 22-01-2015, 15:46
Dival Dival is offline
AKA: Yarden
FRC #3316 (D-Bug)
Team Role: CAD
Dival is an unknown quantity at this point
Retaining Rings use on chassis
Hi!
My team (D-Bug #3316) wants to use retaining rings for our shafts in the WCD chassis. We use aluminum 7075 1/2" hex shaft. Do you have any tips of using retaining rings on those shafts?
2014 Israel Regional Winners! (Special thanks for team #1574 - Miscar and team #3065 - Jatt)
To come up with a complex solution to a complex problem is hard; to come up with a simple solution to a complex problem is even harder; but we both know what makes more fun.
Unread 22-01-2015, 16:22
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
Re: Retaining Rings use on chassis
We ran the same setup last year and everything worked well.
We turned down the portion of the shaft between the end and the retaining ring groove to 1/2" round, as we found that we were likely to yield the retaining ring somewhat if we expanded it wide enough to fit over the hex.
That's really all I can think of at the moment tip wise.
Unread 23-01-2015, 01:38
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
You will specifically want an E-Clip (slide in side mount). Harbor Freight has an assortment box cheap if that's near by, otherwise look at Mc Master Carr. The standard .5 shaft E clip is 0.046 wide by 0.396 ID diameter. That's a lot of Turning on some pretty hard 7075.
Unread 23-01-2015, 03:11
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
We do this with e clips as well. We buy from McMaster.
It's actually quite easy, and we use a cheapo old Grizzly lathe with just 3 speeds and a lot of broken ares to do it.
Using a 0.040" wide grooving tool and a 1" dial indicator, you can get pretty good precision on these parts. 7075 is not that hard to turn a tiny groove in from my experience. We've never milled solid blocks or anything.
Unread 23-01-2015, 03:24
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Are you looking for tooling to do so or? Also I would avoid e clips and use actual snap rings. I see almost no reason to use an e clip over a snap ring in this situation.
R.C.
MadTown Robotics Team 1323
Unread 23-01-2015, 03:33
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
Out of curiosity, why snap rings over e clips? I find e clips are easy to just press on with some pliers but I've never worked with circular snap rings.
Unread 23-01-2015, 04:30
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
My main advice with snap rings is get good pliers. They're amazing with a good pair of snap ring pliers but horrible to get off with a pair with bad tips.
Unread 23-01-2015, 09:29
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
We used e-clips last year, which were great, until we had to take them off without the correct tool.
My advice is to tap the ends of the axles and run short socket cap bolts into the ends with washers bigger than the inner race of the bearings. This allows for much easier maintenance, imho. Just stick a long ball-end hex driver down the frame and you can pull the whole axle assembly off.
Hope this helps!
Unread 23-01-2015, 09:57
InFlight's Avatar
AKA: Jim
This is 0.5 HEX Shaft. You would distort and bend a 0.5 shaft snap ring trying to get it over the 0.577 inch edge-to-edge distance on the hex shaft. The side mount e-clip is the best retainer for the application.
Unread 23-01-2015, 10:00
pfreivald's Avatar
AKA: Patrick Freivald
Not if you turn down the shaft with a .040 groove where you want it. We do it all the time--it's cheap and easy.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 23-01-2015, 10:44
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Could you recommend a good pair? I got a 'set' from somewhere, and they do work - but I've already ruined the two snap rings on the WCP DS's we have and need to replace them before they see competition. Getting the tips into the holes after the snap ring was mounted, even with what we thought was perfect alignment, is what caused the rings to warp.
Unread 23-01-2015, 13:03
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
We use snap rings on our 1/2" hex axles as well. Here's a photo.
Tips:
- Turn down the ends of the shafts so the clips go into the grooves. The clips can't stretch over the hex.
- For applications with any sort of significant side load, use heavy duty snap rings. (McMaster Carr 98585A109) Otherwise, normal ones are fine.
- We highly recommend these snap ring pliers from McMaster Carr: 5449A81
- If a snap ring has any signs of being stretched out, throw it away and use a new one.
- In the heat of competition servicing, don't hesitate to destroy a clip to get it off quickly.
- Don't use the pliers for 3/8" snap rings for 1/2" heavy duty rings. The tips will break off. Hide the 3/8" ones from newbies, or label very plainly. We have ruined two tools in two years from this.
- For most jobs, the straight pliers are easier to use, but every so often the 90 degree ones come in very handy.
- When making the grooves, use a go/no-go gauge (we made our own) to get the diameter of the rings right.
- When turning the ends of the shaft, be sure there is still a tiny bit of black anodize left visible. If not, the ends are too small, and the snap rings may pop off under side load. (like while turning during a match) Most years, your bumpers will keep the wheel from completely falling off, but this year this may not be the case.
- After turning the ends, put a chamfer on the end of the shaft. That knocks off the burr left from parting to length.
- After cutting the grooves, use abrasive paper to knock off the burrs on all six faces of both ends of the shaft. Nothing will slow you down when assembling like burrs.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 23-01-2015, 13:08
Joey Milia's Avatar
FRC #0192 (GRT)
I believe knipex pliers are the ones to go with, I think they're the heavy duty fixed tip ones on McMaster. I might be wrong though, GRT just has the quick change tip ones from McMaster and the tips have gotten misaligned which makes them next to useless. I'm trying to get the team to buy a few of the knipex ones.
