Go to Post Getting that degree is the reason for going to college. Failing out of school because you mentored isn't really a good reason. - [more]
  #61   Spotlight this post!
Unread 23-01-2015, 12:38
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Autonomous Help
Originally Posted by curtis0gj View Post
Sure! What we did was while running an autonomous movement code we were measuring dc voltage across the +5 and the common and we got a reading of +5. Then we ran it across the signal cables to the common and it was showing a square wave pretty much.
I think I found the problem.
In robotInit(), delete the Encoder part of your encoder instantiaton. It should look like this:
encoder = new Encoder(0, 1, false, EncodingType.k4X);
  #62   Spotlight this post!
Unread 23-01-2015, 12:46
curtis0gj curtis0gj is offline
FRC #5033 (Beavertronics)
Rookie Year: 2015
curtis0gj will become famous soon enough
Re: Autonomous Help
Yeah I think that could do it lol heres what I got.
package org.usfirst.frc.team5033.robot;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.Gyro;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.CounterBase.EncodingType;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
public class Robot extends IterativeRobot {
	RobotDrive robot;
    Joystick stick;
    Encoder encoder;
    Gyro gyro1;
    static final double Kp = 0.05;
    public void robotInit() {
    	 robot = new RobotDrive(0, 1);
         stick = new Joystick(0);
         gyro1 = new Gyro(0);
         gyro1.reset();
         gyro1.initGyro();
         encoder.setDistancePerPulse(1);
         encoder.getDistance();
    public void autonomousPeriodic() {
    	gyro1.reset();
    	while(isAutonomous() && isEnabled())  {
    		double angle = gyro1.getAngle();
    		double distance = encoder.get();
    		SmartDashboard.putNumber("Angle", angle);
    		SmartDashboard.putNumber("Distance", distance);
    		robot.drive(-0.25, 1);
    		if(angle > 150) {
    			robot.drive(0,0);
    			gyro1.reset();
    			encoder.reset();
    			Timer.delay(0.5);
    			break;
    			Timer.delay(0.1);
				while (isAutonomous() && isEnabled()) {
						double angle2 = gyro1.getAngle();
						double distance2 = encoder.get();
						SmartDashboard.putNumber("Distance", distance2);
						robot.drive(-0.20, -angle2 * Kp);
						if(encoder.getDistance() < 10)  {
							robot.drive(0,0);
							break;
						Timer.delay(0.1);
  #63   Spotlight this post!
Unread 23-01-2015, 12:47
Flywheel Police
Re: Autonomous Help
	RobotDrive robot;
    Joystick stick;
    Encoder encoder;
    Gyro gyro1;
         gyro1.reset();
         gyro1.initGyro();
    	gyro1.reset();
    		if(angle > 150) {
    			robot.drive(0,0);
    			gyro1.reset();
    			encoder.reset();
    			Timer.delay(0.5);
    			break;
    			Timer.delay(0.1);
							robot.drive(0,0);
							break;
						Timer.delay(0.1);
Looks good. I'm still trying to figure out why you weren't getting NullPointerExceptions with the other code...
  #64   Spotlight this post!
Unread 23-01-2015, 12:51
Rookie Year: 2015
Re: Autonomous Help
Hmm I've no idea what NullPointerExceptions but I don't think want any they sound pretty bad.
  #65   Spotlight this post!
Unread 23-01-2015, 12:52
Re: Autonomous Help
Would you please describe your test setup?
e.g. What were you measuring these voltages with? etc
  #66   Spotlight this post!
Unread 23-01-2015, 12:57
Flywheel Police
Re: Autonomous Help
A NullPointerException happens when you try to access an object like an encoder, but the object has never been given an initial value.
So what seems to have been happening in your old code was because you had that Encoder part on the one line you were declaring a new local variable called encoder which was only used locally, and when robotInit ended it was removed from memory. What this means is that the field you called encoder was never given a value. Take a look at the old code, I'm going to bold the local variable and underline the field so you can see what I'm talking about.
	RobotDrive robot;
    Joystick stick;
    Encoder encoder;
    Gyro gyro1;
         gyro1.reset();
         gyro1.initGyro();
         Encoder encoder = new Encoder(0, 1, false, EncodingType.k4X);
         encoder.setDistancePerPulse(0.001);
    	gyro1.reset();
    		double distance = encoder.getDistance();
    		if(angle > 150) {
    			robot.drive(0,0);
    			gyro1.reset();
    			encoder.reset();
    			Timer.delay(0.5);
    			break;
    			Timer.delay(0.1);
			double distance2 = encoder.getDistance();
				robot.drive(0,0);
				break;
			Timer.delay(0.1);
    public void teleopPeriodic() {
    	while (isOperatorControl() && isEnabled()) {
        	SmartDashboard.putNumber("angle", gyro1.getAngle());
        	stick.getThrottle();
            robot.arcadeDrive(stick.getY(), -stick.getX(), false);
            Timer.delay(0.1);
    public void testPeriodic() {
Do you see how the underlined one never has the statement new Encoder(...) called for it? So it was never given an initial value.
  #67   Spotlight this post!
Unread 23-01-2015, 13:03
Rookie Year: 2015
Re: Autonomous Help
	RobotDrive robot;
    Joystick stick;
    Encoder encoder;
    Gyro gyro1;
         gyro1.reset();
         gyro1.initGyro();
    	gyro1.reset();
    		if(angle > 150) {
    			robot.drive(0,0);
    			gyro1.reset();
    			encoder.reset();
    			Timer.delay(0.5);
    			break;
    			Timer.delay(0.1);
				robot.drive(0,0);
				break;
			Timer.delay(0.1);
            Timer.delay(0.1);
Still not getting anything printed to my smartdash board do I need to make a new dashboard or something like that.
  #68   Spotlight this post!
Unread 23-01-2015, 13:04
Rookie Year: 2015
Re: Autonomous Help
We put the robot on a table and held it up right. Then we got a multimeter and used the dc volts setting. Let me know if you need more info and I can ask the electronic guy.
  #69   Spotlight this post!
Unread 23-01-2015, 13:09
Re: Autonomous Help
It just sounded like you were using either an oscilloscope or on-board voltage sampling. (You said it was "showing" a square wave).
I'm surprised you could actually see the hi/lo voltage transitions with just a multimeter if you were measuring while running your autonomous routine. Are you sure that's what was done? I had suggested turning the encoder very slowly by hand.
  #70   Spotlight this post!
Unread 23-01-2015, 13:10
Flywheel Police
Re: Autonomous Help
You shouldn't need to create a new one. The Distance boxis appearing on the dashboard correct? It just isn't showing any numbers other than 0?
  #71   Spotlight this post!
Unread 23-01-2015, 13:13
Rookie Year: 2015
Re: Autonomous Help
No the box does not even appear so that's why I am wondering if i need to create one or something.
  #72   Spotlight this post!
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: Autonomous Help
This is why you should use command based robot, with a turn x degrees command, drive subsyem with your encoders
  #73   Spotlight this post!
Unread 23-01-2015, 13:15
Flywheel Police
Re: Autonomous Help
You don't need to create one, it should do it on it's own. This is a very interesting one indeed. So the robot is obviously running the code, but the data isn't making it to the SmartDashboard. Are there any errors on your drive station console or in the riolog?
  #74   Spotlight this post!
Unread 23-01-2015, 13:16
Rookie Year: 2015
Re: Autonomous Help
Okay, my mentor told me that he was not really seeing a square wave however, he did see a spike in voltage and a drop in voltage. But we will try spinning it slowly by hand, we took the lazy way out last time because we did not really want to take the encoder off.
  #75   Spotlight this post!
Unread 23-01-2015, 13:22
Rookie Year: 2015
Re: Autonomous Help
None in the ds error box but I don't know how to check the roborio error log.
