Go to Post Justin Bieber says "US FIRST" rather than just "FIRST". The irony. - Ankit S. [more]
Unread 23-01-2015, 15:15
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Re: Talon SRX Breakout Board
The Talon SRX counts the rising edges on the index pin and sends it over CAN using the Quad Status Frame (See section 20.3. Quadrature Encoder Status in software ref manual).
So if you wanted to react to the index pin, you'll have to track it yourself. I figured when you see a change in the index rise count you could re-zero your quad position.
So how exactly did you want to use the index pin? Is quad A/B decoding not sufficient?
Unread 28-01-2015, 15:00
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
What kind of current can the Talon sink/source from the data port. I didn't see the spec in the manual. I'm thinking of hooking up an infrared emitter/detector.
TIA
