Go to Post Ohh the [strike]humanity[/strike] robotity! - artdutra04 [more]
Unread 23-01-2015, 14:37
orangeandblack5 orangeandblack5 is offline
Hates LabView - Uses It Anyway
AKA: Ian Stewart
FRC #5498 (Wired Devils)
Rookie Year: 2015
orangeandblack5 will become famous soon enough
Switch between two cameras?
Hello! I am a first year programmer on a rookie team, and I'm wondering if there is any way to swap between the view of two cameras on the robot by pressing a button. I've been looking this for a couple days to no avail. Any and all help much appreciated!
Unread 23-01-2015, 15:47
Re: Switch between two cameras?
You can do that on the Dashboard.
The same way you switch tabs would be pretty easy.
Just put the camera view in a tab and have a second tab for the other camera.
Unread 23-01-2015, 15:50
And post questions if you have problems figuring out how to get the cameras to switch properly.
Greg McKaskle
Unread 23-01-2015, 15:52
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
You can have both by dragging two camera windows to each side of the monitor. Are you using the axis cameras?
Unread 25-01-2015, 20:59
roialex's Avatar
roialex roialex is offline
FRC #5444 (Vobotik)
Rookie Year: 2015
roialex is an unknown quantity at this point
By doing this this way will it charge the bandwidth twice are when you're going to switch tabs it's going to poweroff the camera you're not using
Unread 25-01-2015, 21:10
Experiment with it. I am pretty sure that you will want to use the tab value to change the value going into the Read MJPEG for Dashboard.
Greg McKaskle
Unread 29-01-2015, 18:24
AKA: Ian Stewart
Rookie Year: 2015
Okay.
First off, thank you all for your help and input so far. I've tried my best going off of what you've all said, but I've made very little progress.
That being said, I will be extremely specific in exactly what I want to do, and if it can be done please let me know (help on exactly HOW to do that would be even more appreciated).
What I would prefer to do is make it so that if you press a button on the joystick (button 2 in my case) it swaps the camera view spot that's already on the dashboard to the other camera's view. I'm trying to do this using a global variable (when button 2 is pressed it equals 1, otherwise it equals 0).
I'm extremely grateful for any further help.
Thank you all so much!
Unread 30-01-2015, 07:56
What type of cameras, USB or IP, or mixed?
Are you doing any processing of images on the roboRIO, or simply forwarding them to the DB?
Greg McKaskle
Unread 03-02-2015, 18:22
AKA: Ian Stewart
Rookie Year: 2015
Two USB cameras, and I believe that I'm just forwarding the images (whatever the default robot code LabView gives you does).
Unread 04-02-2015, 06:57
The default LV code has a loop that will start running its empty vision processing code when enabled on the robotMain front panel or when the global is set to true.
Anyway. The WPILib forwarding code wasn't really prepared for this, so it will take a modification or two.
The Vision Processing VI calls a subVI whose icon has IP & Dash on it. The actual name of the VI is Background loop, and it does several things for different cameras and assumes that the camera address doesn't change.
For USB cameras, it calls a VI labeled Send 2 PC that does the read/compress/send to bridge the USB camera over ethernet. The camera refnum used in that loop is the one that we want to switch back and forth. It is the nested loop that is reading the camera, flattening to a string and calling the Send Image String VI. The inner loop will normally continue as long as the network connection is valid.
The modification would be to Open both cameras and store their refnums in a global variable. Then inside of Send Image to PC, when the camera switches, you'd want to modify the refund and exit the inner loop. The outer loop will stop and start the new camera and reuse the networking connection.
These aren't hard edits, but they need to be done right or they will be hard to debug. If someone makes these edits, perhaps they can share their results with the community?
Edit: It looks like someone has done this in a peer thread. I haven't tested it.
Greg McKaskle
Unread 04-02-2015, 16:14
AKA: Ian Stewart
Rookie Year: 2015
Just saw that today. I'll check up on that, and if it doesn't work I'll try it myself.
Unread Yesterday, 09:07
Nathan Culley Nathan Culley is offline
FRC #2232
Nathan Culley is an unknown quantity at this point
Hello guys, we are trying to switch 2 cameras as well. Please make a link to the code that might work. Or if you guys know code that does work, please let us know.
