Go to Post the point is that FIRST is successful, in so many different ways - Pamela [more]
Unread 23-01-2015, 16:07
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
WPILIB mecanum code not working properly
I have been working on getting our mecanum drive working for the past few days and have run into trouble while trying to program using the WPILIB mecanum class. When we try to drive, the forward and strafe commands work fine, but the turn command doesnt. instead of running the left side one direction and the right side another, it spins the wheels on the right towards each other, and the same on the left. If I invert 2 wheels of any pairing, the axis that doesnt work correctly changes. Below is the code that I am trying to use.
/* Copyright (c) FIRST 2008. All Rights Reserved.                             */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Gyro;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class RobotTemplate extends IterativeRobot {
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
    Joystick MainStick;
    Joystick SecStick;
    Gyro gyro;
    RobotDrive Drive;
    //Drive_Base Drive;
    public void robotInit() {
        MainStick = new Joystick(1);
        SecStick = new Joystick(2);
        gyro = new Gyro(1);
        Drive = new RobotDrive(10,1,2,3);
     * This function is called periodically during autonomous
    public void autonomousPeriodic() {
     * This function is called periodically during operator control
    public void teleopPeriodic() {
        double theta = gyro.getAngle();
        double strafe = 1 * MainStick.getRawAxis(1);
        double forward = -1 * MainStick.getRawAxis(2);
        double rotation = 1* MainStick.getRawAxis(3);
        Drive.setInvertedMotor(RobotDrive.MotorType.kFrontLeft, false);
        Drive.setInvertedMotor(RobotDrive.MotorType.kFrontRight, false);
        Drive.setInvertedMotor(RobotDrive.MotorType.kRearLeft, false);
        Drive.setInvertedMotor(RobotDrive.MotorType.kRearRight, false);
        Drive.mecanumDrive_Cartesian(strafe, forward, rotation, theta);
        SmartDashboard.putNumber("Gyro Angle", theta);
        if(MainStick.getRawButton(8)){
            gyro.reset();
     * This function is called periodically during test mode
    public void testPeriodic() {
        gyro.reset();
However when I change the equations that calculate the wheel outputs from the ones in the WPILIB:
wheelSpeeds[MotorType.kFrontLeft_val] = xIn + yIn + rotation;
wheelSpeeds[MotorType.kFrontRight_val] = -xIn + yIn - rotation;
wheelSpeeds[MotorType.kRearLeft_val] = -xIn + yIn + rotation;
wheelSpeeds[MotorType.kRearRight_val] = xIn + yIn - rotation;
to the following:
double mFL = strafe + forward + rotation;
double mFR = strafe + forward - rotation;
double mRL = strafe - forward + rotation;
double mRR = strafe - forward - rotation;
It drives normally. My issue with changing the equations is that 1) I am using netbeans (old hardware on our practice bot) and cant change the libraries because they are all pre compiled and 2) We are trying to use field centric control and am not getting the results I'd like by trying to write the code using internet resources such as whitepapers by Ether and such.
My thought is that if I can get the WPILIB mecanum working, I can see how their field centric control operates in comparison.
I am really stumped at this point, any help is greatly appreciated.
Unread 23-01-2015, 16:25
Re: WPILIB mecanum code not working properly
Your code and your wiring probably disagree on which motors are in which corner of the robot. Try making some code that lets you control each motor independently so you can verify which physical motor responds to each PWM channel, and in which direction. Note carefully the order that the RobotDrive constructor wants them to be in.
Unread 23-01-2015, 16:50
AKA: Brian Wagg
FRC #2386 (Trojans)
I double checked the port numbers again, all the ports corresponded with the proper wheels. I've taken notes as to the direction each wheel spins individually however at the moment the problem is still there.
Unread 23-01-2015, 17:02
mschwab013's Avatar
mschwab013 mschwab013 is offline
AKA: Matt Schwabenbauer
FRC #0291
mschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to all
Leave the code as is and change the PWM wires. Flip your back left with front right. Or back right with front left
2013 Pittsburgh- Gracious Professionalism award, 7th seed, 6th alliance captian, quarter-finalist(291,3492,4601)
2013 Queen CIty- Chairman's Award, 39th seed
2012 Pittsburgh- 23rd seed
2012 Buckeye- 34th seed, 2nd alliance, quarter-finalist(291,1241,4085)
2011 Pittsburgh- 13th seed, 5th alliance, quarter-finalist(291,337,3504)
2011 Buckeye- 18th seed, 8th alliance, quarter-finalist(279,291,3496)
2010 Finger Lakes- 15th seed, 5th alliance, quarter-finalist(291,1507,1559)
2010 Buckeye- Chairman's Award, Imagery Award, Quality Award, 4th seed, 1st pick, 1st alliance, semi-finalist(291,1014,1629)
Unread 23-01-2015, 17:36
AKA: Brian Wagg
FRC #2386 (Trojans)
If I change the pwm cables (front left and rear right or front right and rear left) it just changes the axis that is not operating properly (the wheels spin towards each other). just like when I invert the motor pairs in the code.
Unread 23-01-2015, 17:44
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Do you have the wheels mechanically mounted correctly? When looking from the top, the rollers should look like an X across the robot.
Also, unless gearing is different for each side, one side of the drive should be reversed, and one side should be normal. This should allow rotation correctly.
One way I like to check things is look at the lights on the motor controllers.
When going straight, 2 should be red, and 2 should be green.
When rotating, all 4 should be either red or green, depending on which direction you are rotating.
When strafing, 2 of the corners should be red, and the other 2 corners should be green.
1 More thing to check. When driving at a 45 degree angle, only 2 of the motors should be spinning, and they should be the 2 perpendicular to the direction you want to move. If thats not working correctly, then its most likely that either motor reversing isnt right, or the PWM ports are wrong.
Team 4488 - Mentor 2013-2016
Unread 23-01-2015, 17:46
baumgartensam's Avatar
baumgartensam baumgartensam is offline
AKA: Sam Baumgarten
FRC #0751 (Barn2Robotics)
baumgartensam will become famous soon enough
What I would recommend doing is printing out your X and Y input and then your wheel outputs. Confirm X and Y are in-fact what you intend and then check that the correct wheels are moving. If that doesn't work, you could always subclass RobotDrive and then override the following methods:
public void mecanumDrive_Cartesian(double x, double y, double rotation, double gyroAngle);
public void mecanumDrive_Polar(double magnitude, double direction, double rotation);
If none of this works, could you make a codebase with only drive code and posting it here?
Good luck!
Unread 23-01-2015, 17:53
mschwab013's Avatar
FRC #0291
Can you describe exactly what each wheel does when given each command?
Unread 23-01-2015, 18:31
AKA: Brian Wagg
FRC #2386 (Trojans)
At the moment I've been able to get field centric control working using my own code but am still trying to work out what is wrong with my code that utilizes the robot drive class. Unfortunately I've had to go home for the night and won't be able to test any more code until at least tomorrow. Might just leave the wpilib for now and continue with my own mecanum code.
Unread 23-01-2015, 18:35
mschwab013's Avatar
FRC #0291
If it works then go for it. I'm glad its working now
Unread 23-01-2015, 18:46
You say this works:
You also show that none of the motors are inverted in the initialization.
That's weird. Your rear motors are reversed, and strafing definitely shouldn't run all the motors in the same direction. I suggest that you triple-check your wiring. And have someone else check it again afterwards. In fact, take some good photos of how you have it wired up and post them here so we can all go over them.
Something is definitely wrong, and I do not believe it is the WPI library.
Unread 23-01-2015, 19:10
AKA: Brian Wagg
FRC #2386 (Trojans)
Originally Posted by Alan Anderson View Post
You say this works:
Believe me, I too am almost certain that its nothing wrong with the WPI. I will try and get some photos tomorrow however the wiring is pretty messy as it sits. hopefully we can clean it up some time soon.
Unread 23-01-2015, 20:00
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Is there a reason your robot drive is *10*,1,2,3? did you mean 0? And make sure the order you set the drive motors is frontLeft, rearLeft, frontRight, rearRight.
Check for inverted motors*** . If the transmission causes the motor to spin the same way as the wheel, then the left side should be inverted
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 23-01-2015, 21:01
^^^This.
Unread 24-01-2015, 08:58
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
We had a similar issue a few weeks ago. My student had swapped the x and y joystick inputs into the mechanum code call. It is not asking for field x and y but joystick x and y. Also the mechanum internally inverts the y so you don't have to.
