Go to Post Darn kids, how can they not be addicted to ChiefDelphi? - Kyle Love [more]
Unread 23-01-2015, 15:37
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Python: TypeError: unorderable types: complex() > float()?
Hi! We have a problem when trying to sqaure root our contoller's left and right axis for a nice speed curve. The error message is:
. I am doing
self.robot_drive.arcadeDrive(cmath.sqrt(self.joystick.getX()),cmath.sqrt(self.joystick.getX()))
Any help will be greatly appreciated!
Unread 23-01-2015, 15:46
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: Python: TypeError: unorderable types: complex() > float()?
Shot in the dark guess: taking the square root of getX(), which can sometimes be negative, will give you an imaginary value. You need some way to avoid that and only produce real numbers for arcadeDrive().
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 23-01-2015, 16:05
Even after accounting for the sign of the value, taking the square root sounds like it would bend the speed curve in the wrong direction. It would make the motors more sensitive to small inputs, instead of giving the driver more low-speed control. Most suggestions I see call for squaring or cubing the joystick value.
Unread 23-01-2015, 16:36
team-4480's Avatar
Debug? What's that?
FRC #4480
My bad....I mixed those up....Thanks!
Unread 24-01-2015, 22:02
team-4480's Avatar
Debug? What's that?
FRC #4480
How would you square negatives? Thanks!
Unread 24-01-2015, 22:09
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
RobotDrive has support for this built in, so you should be able to just use this:
self.robot_drive.arcadeDrive(self.joystick.getX(), self.joystick.getX(), true)
This is how it is done internally:
if squaredInputs:
            # square the inputs (while preserving the sign) to increase fine
            # control while permitting full power
            if moveValue >= 0.0:
                moveValue = (moveValue * moveValue)
            else:
                moveValue = -(moveValue * moveValue)
            if rotateValue >= 0.0:
                rotateValue = (rotateValue * rotateValue)
            else:
                rotateValue = -(rotateValue * rotateValue)
