Go to Post Safety captains be watchful. - Al Skierkiewicz [more]
Unread 22-01-2015, 19:51
abraker abraker is offline
FRC #0333
abraker is an unknown quantity at this point
Wierd roboRIO lag spike
Hi teams!
We are trying to debug encoders to get an accurate reading, and determined that some sort of lag spikes happen randomly. I stripped the loop so that it only checks for a raw value (for debugging purposes), and stops the motor when the value is >=1440 (360 deg rotation using k4X encoding type) and prints the number of milliseconds it took. Most of the time it runs for ~630 ms, but when the random lag spike hits, it runs for anywhere between 700 ms to 800 ms.
Our loop:
t1.set(0.15);
t2.set(0.15);
while(isAutonomous() && isEnabled()){
   if(encoder.getRaw())>=1440-56){  // it overshoots everytime, so -56 to compensate
      t1.set(0.0);
      t2.set(0.0);
      clock.stop();
      SmartDashboard.putNumber("Timer: ", clock.get());
Unread 23-01-2015, 15:46
Re: Wierd roboRIO lag spike
Does the driver station log show anything when this happens?
Unread 23-01-2015, 16:33
FRC #0333
Where do I find the log files?
Unread 23-01-2015, 16:34
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Where is this code segment located?
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 23-01-2015, 16:40
FRC #0333
inside
public void autonomous()
the logs just read "Warning" and "WARNING" messages and nothing else
Edit: The warning are just for events like Driver station loosing communication, and other network communication events probably from reloading the code.
Unread 23-01-2015, 16:44
AKA: Spencer Lanman
Try putting a
Timer.delay(0.05);
in the loop. That will reduce the load on the roboRIO.
Edit: Sorry
Timer.delay(0.005);
is what I meant to put, 50 ms of delay is probably extensive.
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 23-01-2015, 16:57
FRC #0333
When I put in the timer delay, it's not updating fast enough and overshoots inconsistently.
EDIT: I tried the 0.005 timer delay. It's more consistent, but still hiccups. Every 6-12 times we test it, it overshoots by a lot, somewhere from 100 ms to a second longer overshoot.
Unread 23-01-2015, 17:05
AKA: Spencer Lanman
When you say it overshoots, are you saying the encoder data is correct but the motors do not respond until 100 ms after they should have stopped?
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 23-01-2015, 17:09
FRC #0333
Yes the encoder data is correct, and yes the motor randomly stops later than intended.
Unread 23-01-2015, 17:15
AKA: Spencer Lanman
I don't see any reason in the code for that to happen. I would ensure the encoder is providing proper feedback, maybe adjust oversampling rates, etc. You should also try using a PID loop and see if smarter code can compensate for the lag.
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 23-01-2015, 17:18
FRC #0333
Note that it happens randomly. Most of the time it does a beautiful 360 and is deadly accurate.
