Go to Post "The compressor is half the temperature of a toasted Subway sandwich." - Ashley Hartley [more]
Unread 22-01-2015, 16:55
Dave_4539 Dave_4539 is offline
AKA: David
FRC #4539 (KAOTICRobotics)
Team Role: Driver
Dave_4539 is an unknown quantity at this point
Problems with Driver Station
I have been recently trying to update our drivers station for this year. I have been following the instructions on usfirst.org. I got to the second page and it wants me to open a desktop icon titled, FRC driver station. No such icon is appearing for me. Any help?
Unread 22-01-2015, 17:13
Re: Problems with Driver Station
What instructions are you following? The desktop icon was there with last year's system. This year you find it in the Start menu.
Unread 22-01-2015, 19:57
AKA: David
Team Role: Driver
I looked there... no luck...
Unread 22-01-2015, 19:59
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
Are you running Windows?
You can just search for driver station in the search box and it will appear. Otherwise our team was able to find it embedded in the update folder.
College sux yo
Unread 23-01-2015, 09:20
AKA: David
Team Role: Driver
Unless its not named FRC driver station, it doesnt appear when I search for it, nor can I find it in the update folder...
Unread 23-01-2015, 09:23
It should be in:
C://Program Files/FRC Driver Station
Program Files may be Program Files (x86) depending on your computer.
It gets installed with the FRC Update.
Did you follow these directions: Installing the FRC 2015 Update Suite (All Languages)
Unread 23-01-2015, 10:19
AKA: David
Team Role: Driver
Nope... I followed directions from usfirst.org under frc...programming...driver station... so I will try those directions and see if that works... thanks!
Unread 23-01-2015, 12:46
You got to the ScreenSteps site okay, but it doesn't look like you went through the Getting Started with the 2015 Control System section. The Installing the FRC 2015 Update Suite (All Languages) is where it steps you through putting the software in the right place.
Unread 23-01-2015, 17:15
AKA: David
Team Role: Driver
Well I figured it out. It was just a National Instrument Update that hadn't been done. But now, when I log in as driver, the dashboard doesn't pop up like it has in the past. Its not a huge deal to us, but there is like two windows and the resolution is huge, and we can't see them both at one time. Is there some setting we can change in order to see everything?
Unread 23-01-2015, 17:18
Are you using the floating or docked window mode? In docked, it should scale to the resolution.
Unread 23-01-2015, 17:20
Is this on a Classmate or another laptop?
Did you set the task bar to Auto Hide and make more room on the screen?
Do the two windows have frames?
Unread 23-01-2015, 17:27
AKA: David
Team Role: Driver
Yeah, I auto-hid the task bar but it still doesn't snap to the correct resolution.
Unread 23-01-2015, 18:28
If you don't answer the questions we're asking, we can't do a good job of advising you further. To summarize what we still want to know:
Are you using the "floating" or "docked" window mode? If you don't know what that means, just tell us whether or not the windows have title bars.
Is this a Classmate laptop? If you don't know what that means, just tell us what brand of computer you are using.
Unread 23-01-2015, 21:19
AKA: David
Team Role: Driver
It is a classmate laptop, when i open the frc driver station icon on the desktop, it splits it into two windows, both of which are floating, and extending past the screen so I cant see all of it. I can only dock one of the windows to the top, making it impossible to see the other window...
Unread 23-01-2015, 22:09
Look for this on the Driver Station and click it.
