Go to Post What? No Poof balls as pillows? Phfff. Amateur. :p - artdutra04 [more]
Unread 23-01-2015, 17:19
sjaques sjaques is offline
FRC #2874
sjaques is an unknown quantity at this point
Error with Pneumatic
We are continuing to have an error 44007 occurred at periodic tasks.vi>>roboti main.vi 2015. Any help would be great. We double checked our wiring and everything is getting power. The compressor just doesn't want to cooperate with us. Thanks in advance.
Unread 23-01-2015, 17:59
Re: Error with Pneumatic
Error -44007 means you're trying to do a RefNum Get on a name that you haven't done a RefNum Set for. Double-check that you have everything spelled correctly, and that everything's type matches up (you aren't accidentally trying to set a Motor when you opened a 2 Motor Drive, for example).
Unread 24-01-2015, 12:14
FRC #2874
Checked that. Thanks. We had hope it was a simple issue that had been overlooked. Still a struggle. We'll keep you posted.
Unread 24-01-2015, 15:46
FRC #2874
We worked it out.
Unread 07-02-2015, 12:28
Team5709 Team5709 is offline
FRC #5709
Team5709 is an unknown quantity at this point
Could anybody walk us through what do, or how to fix the problem?
