Go to Post Would FIRST be as amazing if not for CD? I mean it would still be this amazing place for students and mentors to be but the explosion of innovation and gathering of people together across communities has to have been greatly effected by CD. - dodar [more]
Unread 23-01-2015, 16:52
JohnGaby JohnGaby is offline
FRC #2102
JohnGaby is an unknown quantity at this point
Is MXP UART.RX 5v tolerent
Is the UART RX pin on the MXP port 5v tolerent? In other words, can I safely connect the TX from a 5v Arduino to that line, or do I need a level shifter?
Thanks.
Unread 23-01-2015, 17:20
Re: Is MXP UART.RX 5v tolerent
Yes, per the specifications: https://decibel.ni.com/content/docs/DOC-30419
Unread 23-01-2015, 19:05
FRC #2102
Originally Posted by Joe Ross View Post
Are you sure about that. I cannot find anything in the spec you referenced that addresses this issue (perhaps I am missing it?), only a comment down below. Also there is another comment stating that the UART on the MXP is 3.3v TTL.
The thing that worries me is that it is documented that the RX pin has a 40K pull up resistor to 3.3v, and it indeed seems to be pulled up to 3.3v when I look at it on a scope. What happens then when I try and drive it to 5v with and Arduino?
Thanks.
Unread 23-01-2015, 19:13
Sorry, it's spread across two documents. In the User manual, page 9 it says that the MXP uart are electrically the same as DIO lines.
In the specifications, it shows that DIO are 5V compatible input.
If you have further confusion, I'd suggest asking NI.
Unread 23-01-2015, 19:44
FRC #2102
Ok, I see it, thanks.
Unread 23-01-2015, 21:03
FRC #2102
For anyone else who might be hesitant to try this, I went ahead wired the RoboRio's RX to the Arduino's TX and both functioned as expected and I was able to transmit data across the serial line.
Thanks for your help.
