Go to Post Teams that take care of the little things often have much less trouble with the big things! - dtengineering [more]
Unread 17-01-2015, 15:42
Herbblood's Avatar
Herbblood Herbblood is offline
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
Herbblood is an unknown quantity at this point
Network tables
Has anyone done much with the new update to network tables?
I'm trying to get the the robot to connect to a custom dashboard using jframes and network tables. Anyone know how i should use network tables to do this?
Off to WPI!
Go OxBE4
Unread 18-01-2015, 19:56
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Network tables
Check out this post from the 2014 documentation.
http://wpilib.screenstepslive.com/s/...e#!prettyPhoto
I think it will still work. You'll need to create a desktop java program and include the NetworkTables.jar in your project from the <user>/wpilib/java/currrent/lib folder. Then just try that example. I'll give it a try tomorrow with a robot to verify that it works, then move that page into the 2015 documentation.
Be sure to add the library to the Project Properties, Java build path, libraries project settings.
Brad Miller
Robotics Resource Center
Unread 18-01-2015, 21:11
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: Network tables
I was able to get a desktop program to connect to the smart dashboard using network tables so I am pretty sure it still works.
Unread 20-01-2015, 15:48
Herbblood's Avatar
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
Re: Network tables
Thank you so much!
This year is my first with working with network tables, so I hope this works!
Off to WPI!
Go OxBE4
Unread 23-01-2015, 21:17
Herbblood's Avatar
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
Re: Network tables
To add on to this, does anyone know of getting the camera images onto the custom dashvboard? I need to get both the usb and axis images.
Off to WPI!
Go OxBE4
Unread 23-01-2015, 21:37
Head programmer
Re: Network tables
find the ip addresses of the cameras using the webdashboard for the roborio located at "roborio-####.local" where #### is your team number, or something similar to it.
