Go to Post Volunteer...it will make you see a totally different side of FIRST. - Collin Fultz [more]
Unread 21-01-2015, 03:12
JackOfAllTrade5's Avatar
JackOfAllTrade5 JackOfAllTrade5 is offline
Captain
AKA: Austin
FRC #3673 (C.Y.B.O.R.G. SEAGULLS)
JackOfAllTrade5 is an unknown quantity at this point
Lightbulb WIRING AN ENCODER TO ROBORIO
My team has never used an encoder before but we want to use the planetary gear box motor that came in this years KOP and it has a built in encoder. We found an encoder wire from years past but the plug doesn't fit into the encoder on the motor. Any help would be greatly appreciated!
Unread 21-01-2015, 06:15
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Re: WIRING AN ENCODER TO ROBORIO
As per AndyMark's page on the encoder, you'll need this cable.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 21-01-2015, 16:10
Captain
AKA: Austin
I see that I need that cable but I need to know how to plug it into the Roborio, that is my problem.
Unread 21-01-2015, 17:48
timytamy's Avatar
AKA: Tim
It plugs into the DIO ports.
the red and black cables are +5V and GND respectively, while the green and red are your two signal wires (so go to one sig channel each)
Tim W
Sydney, Australia
Unread 21-01-2015, 18:54
Kellen Hill's Avatar
Kellen Hill Kellen Hill is offline
Strategist
AKA: The user formerly known as 'hill'
FRC #1746 (OTTO)
Kellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond repute
I've done a bit of searching on this myself as someone who is using encoders for the first time on a robot.
What doesn't seem to be mentioned very often is that each encoder requires 2 DIO ports on the RoboRio. If I'm correct, I don't believe it matters which port of the 2 ports the ground and the +5v go into, but the two signal wires then go onto the signal pins for the 2 dedicated ports for that encoder.
Make sense? Feel free to correct me if you have a better idea on the subject. This is just what I've managed to dig up.
1625 Winnovation Member: 2005-07
1625 College Mentor: 2007-11
525 Swartdogs Mentor: 2011-12
1746 OTTO Lead Mentor: 2013-Present
Unread 23-01-2015, 21:00
Dexterium's Avatar
Dexterium Dexterium is offline
AKA: Adam Poindexter
FRC #1208 (Metool Brigade)
Dexterium is an unknown quantity at this point
Useful diagram found in LabVIEW encoder example
Unread 23-01-2015, 22:11
Captain
AKA: Austin
I figured it out! Well actually our coding mentor did, your guys' input was valued. It was basically what Dexterium said so thanks guys!
Unread 30-01-2015, 15:06
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Question Re: WIRING AN ENCODER TO ROBORIO
What did you put on the unterminated ends of the wires to get them to plug into the pins on the RoboRIO? I think we need single-pin female jumpers that we can put the wires into. What are people using?
FRC 2656 | FTC 5526 | VEX 9656
Unread 30-01-2015, 19:50
We use the female end of two PWM cables.
