Go to Post Think, Write, Re-Think, Erase or Post - and Deal With it Either Way. - Chris Fultz [more]
Unread 24-01-2015, 12:26
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: Accessing .mjpg stream from camera to process
Originally Posted by Arhowk View Post
Vision programming. The entire thing is really buggy with next to no documentation whatsoever and the only sample code doesn't even process an image.
yeah, exactly that! Also I do not think there is a support for the axis camera series, just Usb webcams
Unread 24-01-2015, 12:59
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
AxisCamera.java?
Unread 24-01-2015, 13:30
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
AxisCamera.java?
Have you had any success with actually connecting to the camera from the robot?
Unread 24-01-2015, 13:48
Head programmer
That class was made for last year's vision system. Also I have tested it this year and does not work.
Unread 24-01-2015, 21:10
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
You can use OpenCV VideoCapture object. You could also edit the smart dashboard camera view.
Unread 25-01-2015, 12:44
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
I also confirm that it works, though CameraServer has a 2-3sec lag compared to SmartDashboard's direct connection which gets a ~100ms lag
Unread 25-01-2015, 19:04
Head programmer
what Axis camera? I used an axis m1013 and it did not, maybe I will revisit it.
Unread 26-01-2015, 08:55
Flywheel Police
We were finally able to get it running, but not with the AxisCamera. The robotRio sees the IP camera as cam0, so I was able to use it just like the USB cameras. Thank for the help.
