Re: Accessing .mjpg stream from camera to process
AxisCamera.java?
Have you had any success with actually connecting to the camera from the robot?
That class was made for last year's vision system. Also I have tested it this year and does not work.
You can use OpenCV VideoCapture object. You could also edit the smart dashboard camera view.
I also confirm that it works, though CameraServer has a 2-3sec lag compared to SmartDashboard's direct connection which gets a ~100ms lag
what Axis camera? I used an axis m1013 and it did not, maybe I will revisit it.
#7
We were finally able to get it running, but not with the AxisCamera. The robotRio sees the IP camera as cam0, so I was able to use it just like the USB cameras. Thank for the help.
