Go to Post Read the manual! - Trent B [more]
Unread 17-01-2015, 15:11
davidtw614 davidtw614 is offline
FRC #2537
davidtw614 is an unknown quantity at this point
CAN Bus Java Documentation with Custom Sensors
Hi guys,
Is there anyone who can provide information on any WPIlib documentation on communicating with custom sensors (IR, Ultrasonic, LIDAR, etc.) between the Robo-rio and the CAN Bus? Our team can't seem to find any specific documentation on this stuff other than some basic send/receive methods.
Thanks in advance!
David
Unread 17-01-2015, 22:34
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Re: CAN Bus Java Documentation with Custom Sensors
There aren't any simple wrapper classes for general-purpose CAN communication in WPILib, mostly because every device is a little different. However, you can technically call the FRCNetworkCommunication functions directly. It would look something like this, but you need to fill in the blanks for device-specific things. I'm also not sure if the message tokenization stuff will interfere with it.
PHP Code:
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.can.CANExceptionFactory;
import edu.wpi.first.wpilibj.can.CANJNI;
import java.nio.ByteBuffer;
import java.nio.IntBuffer;
import java.util.Arrays;
public class
Robot extends IterativeRobot {
/* Check the datasheets for your device for the arbitration IDs of the
        messages you want to send.  By convention, this is a bitstring
        containing the model number, manufacturer number, and api number. */
private static final int MESSAGE1_ARB_ID 0x1;
int MESSAGE2_ARB_ID 0x2;
/*  Device ID, from 0 to 63. */
private static final int DEVICE_NUMBER 1;
    private
IntBuffer status ByteBuffer.allocateDirect(4).asIntBuffer();
    private
IntBuffer messageId ByteBuffer.allocateDirect(4).asIntBuffer();
    private
ByteBuffer data ByteBuffer.allocateDirect(8);
    private
ByteBuffer timestamp ByteBuffer.allocate(4);
     * Send a message once when the robot program starts
public void robotInit() {
/* Again, see the datasheet for the device you're using.  It should
            specify what data to put here. */
data.clear();
data.putFloat(3.14f);
data.putInt(3);
data.putChar('a');
/* Alternatively, instead of CAN_SEND_PERIOD_NO_REPEAT, you can specify
            a period in milliseconds to automatically send the message over
            and over again. */
status.clear();
CANJNI.FRCNetworkCommunicationCANSessionMuxSendMessage(
MESSAGE1_ARB_ID DEVICE_NUMBER,
data,
CANJNI.CAN_SEND_PERIOD_NO_REPEAT,
status
CANExceptionFactory.checkStatus(status.get(0), MESSAGE1_ARB_ID);
     * Check for an incoming message periodically, and print it out if one
     * arrives.
@Override
public void teleopPeriodic() {
/* To receive a message, put the message ID you're looking for in this
            buffer.  CANJNI...ReceiveMessage  will not block waiting for it,
            but just return null if it hasn't been received yet. */
messageId.clear();
messageId.put(0MESSAGE2_ARB_ID DEVICE_NUMBER);
status.clear();
ByteBuffer data CANJNI.FRCNetworkCommunicationCANSessionMuxReceiveMessage(
messageId,
CANJNI.CAN_MSGID_FULL_M,
timestamp,
status
        if (
data != null) {
System.out.println("Received a message: " Arrays.toString(data.array()));
Unread 21-01-2015, 17:19
FRC #2537
Thanks!
Do you know if there's anyway to actually use the data from the sensors (as like a variable) and manipulate it? Or can we only just print these messages?
Unread 21-01-2015, 17:39
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
Thomas's example demonstrates how to send and receive CAN frames (nice job!). What goes into and out of the frames depends on what CAN device you want to talk to. Wpilib uses this to implement support for ...
CAN Talon SRX
CAN Jaguar
...but you can write your own logic to support other CAN devices (As long as they are legal).
Did you have something specific in mind?
Also if you're just trying to get more analog channels easily, you can wire to the analog input of the Talon SRX and grab its decoded analog value over CAN bus. See software reference manual for details.
Unread 22-01-2015, 19:39
FRC #2537
CAN Talon SRX
CAN Jaguar
Good point. Our team was playing around with reading data from custom sensors (not the motor controllers) like LIDAR, IR etc. I guess we have to write our own logic to support this?
Unread 24-01-2015, 14:55
ozrien's Avatar
Omar Zrien
AKA: Omar
Are these CAN sensors or analog sensors?
