Go to Post I'm exceptionally bad at taking my own advice, is all. - Libby K [more]
Unread 24-01-2015, 14:24
mandrews281 mandrews281 is offline
FRC #0281
mandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to behold
WPI Library Documentation -- Local Copy?
I really miss having the WPI library documentation on the local machine this year. When your programming laptop is connected to the robot for debugging, it doesn't have internet access to get online documentation.
Has anyone generated (or can explain how to generate) a standalone 2015 WPILib.chm file yet?
WPILib team (if you're listening), please make this a priority for the next update. Pretty please?
Michael Andrews
Team #281 Programming Mentor
Unread 24-01-2015, 15:08
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Re: WPI Library Documentation -- Local Copy?
Second the motion
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 25-01-2015, 15:18
FRC #0281
OK I downloaded doxygen and MS HTML Help Workshop and generated a file myself. Pointed it at the include directory and voila (see attached file).
It's a bit of a mess since I've never worked with doxygen before (lots of extra structures that were in the include files but are not meant for direct use by the programmer); but it's a start.
Does anyone have a decent doxyfile that will cut down on the output?
Michael Andrews
Unread 25-01-2015, 15:51
The doxy file that WPI uses is here: https://usfirst.collab.net/gerrit/gi...da2 3;hb=HEAD
Unread 25-01-2015, 16:57
FRC #0281
Much better. There were a couple of excludes in there that cleaned things up nicely. Here's the updated file everyone. Enjoy (I am).
I didn't know WPILib moved to CollabNet (from FIRSTForge). I was going to complain about the source not being available next .
Michael Andrews
Unread 29-01-2015, 22:10
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
The documentation is already on your computer. It's in $HOME/wpilib/java/current/javadoc/index.html.
Unread 29-01-2015, 22:14
That's for java...
Unread 30-01-2015, 00:31
gwlund gwlund is offline
FRC #2605
gwlund is an unknown quantity at this point
Thanks. Don't forget to let everyone know that MS Windows blocks CHM help files from unknown sources. Click the file properties and click the Unblock button to get the content to display.
Unread 30-01-2015, 17:20
FRC #0237
Originally Posted by RufflesRidge View Post
That's for java...
Doesn't matter. It's the same library, but with camel case method names.
Unread 30-01-2015, 17:40
Even if the API was 100% identical (which I'm not sure it is) my point was that if you don't install the Java plugin, because you're not programming in Java, you won't have that folder at all.
Unread 26-07-2015, 23:59
JohnGaby JohnGaby is offline
FRC #2102
JohnGaby is an unknown quantity at this point
I know this is an old thread, but I just downloaded both versions of 2015_WPILib.zip and although I can open the 2015_WPILib.chm file and see the list of topics, I cannot get any of the topics to display. Does anyone have any idea why this might be?
Thanks.
