Go to Post We had an autonomous bug last year . . . Funnily enough, this worked real well and other teams were asking us for this "feature." - dragoonex [more]
Unread 16-01-2015, 09:45
team5050ctr's Avatar
team5050ctr team5050ctr is offline
FRC #5050
team5050ctr is an unknown quantity at this point
the usb camera
i was wondering how you would hook up the Microsoft USB camera from andymark to the robot and program it?
Unread 16-01-2015, 12:56
Re: the usb camera
It's a USB camera. Plug it into one of the roboRIO's USB connectors.
What programming language do you use to program your robot? The default LabVIEW project already includes the code to forward the camera image to the Dashboard for display. Examples in C++ and Java show what you need to add to your program for it to do the same thing. Other examples show how to process the image in order to get useful information for your program to use.
Unread 17-01-2015, 22:29
landinw's Avatar
landinw landinw is offline
AKA: Bill Landin
FRC #2377 (C-Company)
landinw is an unknown quantity at this point
Re: the usb camera
Our team is using the LifeCam USB camera with Java. It's working fine on the default PC Dashboard with the Simple Vision sample program, but we can't get an image on the SmartDashboard. We'd like to use the SmartDashboard - any ideas what we should check to get the camera to display on it?
Unread 17-01-2015, 23:03
Adam8234's Avatar
Adam8234 Adam8234 is offline
Controls Captain
AKA: Adam Corpstein
FRC #2052 (KnightKrawler)
Adam8234 will become famous soon enough
Re: the usb camera
My team successfully got the Microsoft camera to work with the default dashboard. We just added the code from the simple vision example to our existing code, but we haven't specifically tried SmartDashboard, but it's on our list. I will let you know if we get it to work on SmartDashboard.
Unread 17-01-2015, 23:12
Re: the usb camera
One thing we've noticed is that there is a single socket, and the LabVIEW dashboard doesn't close it when you turn off the camera. We've needed to close the LabVIEW dashboard and then start SmartDashboard to get it to work.
Unread 24-01-2015, 16:15
Kyle Chan's Avatar
Kyle Chan Kyle Chan is offline
FRC #0368 (Kika Mana)
Kyle Chan is an unknown quantity at this point
Re: the usb camera
We are also having this problem. After applying the new WPILib update last week, we noticed that the USB Camera was not connecting on SmartDashboard but it worked fine on the default dashboard.
