Go to Post One thing that FIRST has given me ... Friends who care. - Arefin Bari [more]
Unread 24-01-2015, 16:36
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Pneumatics Wiring
I'm surprised that the compressor is connected directly to the PCM. See http://wpilib.screenstepslive.com/s/...he-2015-system.
Past (2014 etc), the wiring requirements included the PDB with a circuit breaker and a relay (which included a fuse).
Strikes me as odd.
How do we not need to same safety and isolation features?
Seems like we could still wire the compressor the old way, but why aren't we required to wire through the PDP?
Thoughts? Comments?
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 24-01-2015, 17:18
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Jalerre is on a distinguished road
Re: Pneumatics Wiring
Strikes me as odd.
Thoughts? Comments?
I would just like to point out that the PCM is connected to PDP and has a 20A fuse on the port that it is connected to. And of course the PDP is connected to the main breaker.
Unread 24-01-2015, 17:32
duane's Avatar
Thank you! I hadn't worked back that far with the wiring to notice the additional protection.
That makes me feel better.
Duane Murphy
Mentor - Software
Unread 24-01-2015, 22:06
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
The PCM also has some fancy circuitry that's able to detect shorts/other faults and shut down the compressor way faster than a fuse/breaker.
Unread 26-01-2015, 12:16
FireAmpersand's Avatar
FireAmpersand FireAmpersand is offline
AKA: Manning Team Co-Captian
FRC #4627 (Manning Robotics)
Team Role: Electrical
FireAmpersand is an unknown quantity at this point
It also has an automatic shut-down to the compressor if the limit switch ever becomes disconnected or unresponsive.
Unread 03-02-2015, 16:25
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Can we wir the Old Festo Solenoids
TEAM 1946-Tamra
Unread 03-02-2015, 17:10
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Though it only takes 12V inputs, it does have a jumper to switch to 24V output. Was this your concern?
More detail on this at:
http://khengineering.github.io/RoboRio/faq/pcm/
Unread 04-02-2015, 01:57
yara92's Avatar
AKA: Mohamed
Thanks I found this
Single Solenoid came in previous Kits and is marked as model # VPLE18-M5H-4/2-1/4
Festo Solenoid Valve Assembly (Adobe PDF, 41 KB) http://www.team358.org/files/pneumatic/
On some of these special order valves the wiring does not follow the standard directions (use terminals 1 & 2). If your valve doesn't work when power is applied, then switch your positive wire from terminal 2 to terminal 3 (use terminals 1 & 3).
TEAM 1946-Tamra
