Go to Post I am speechless......but I will think of something by the time it becomes an obvious candidate for the photo caption contest. - Rich Wong [more]
Unread 24-01-2015, 09:49
Re: WPILIB mecanum code not working properly
Originally Posted by engunneer View Post
It is not asking for field x and y but joystick x and y.
...unless you are using mecanum_Cartesian with a gyro signal connected to the gyro input. Then it is expecting field-centric inputs.
Unread 24-01-2015, 10:21
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
We were using all of those. The input parameter called x expects the x position of the joystick. The y parameter expects the y joystick position with no inversion. Our robot immediately started driving properly with field centric controls once this was straightened out.
Unread 24-01-2015, 10:23
AWoL's Avatar
AWoL AWoL is offline
Lvl. 225 Dark Code Mage (Java Type)
AKA: Adam Wolnikowski
FRC #0225 (TechFire)
AWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond repute
Originally Posted by cad321 View Post
wheelSpeeds[MotorType.kFrontLeft_val] = xIn + yIn + rotation;
wheelSpeeds[MotorType.kFrontRight_val] = -xIn + yIn - rotation;
wheelSpeeds[MotorType.kRearLeft_val] = -xIn + yIn + rotation;
wheelSpeeds[MotorType.kRearRight_val] = xIn + yIn - rotation;
to the following:
double mFL = strafe + forward + rotation;
double mFR = strafe + forward - rotation;
double mRL = strafe - forward + rotation;
double mRR = strafe - forward - rotation;
Maybe I missed something here, but may I ask why you changed the signs in the equations?
2016 Competition Results (Co-captain, Driver, and Lead Programmer; Junior)
Springside-Chestnut Hill District Event - WINNER / #2 Seed, #1 Seed's First Pick / Gracious Professionalism Award
Westtown District Event - WINNER / #1 Seed / Industrial Design Award
MAR District Championship - WINNER / #1 Seed / Industrial Design Award / Dean's List Finalist Award (Me)
World Championship, Carson Subdivision - QUARTERFINALIST / #3 Seed, #2 Seed's First Pick
Indiana Robotics Invitational - FINALIST / #14 Seed, #2 Seed's Second Pick
Unread 24-01-2015, 15:00
krieck's Avatar
krieck krieck is offline
AKA: Keith
FRC #2846 (Firebears)
krieck is an unknown quantity at this point
Looking at the code for RobotDrive, I can see that the gyroAngle is used to rotate the values of xIn and yIn. This is what creates the field-centric driving.
Your code that works appears to put the values of "strafe", "forwards", and "rotation" directly into the motor controllers.
Are you discarding the rotation from the gyroAngle to get driving to work normally? In other words, could you get good normal driving behavior by keeping the gyro angle at a constant zero?
Unread 24-01-2015, 16:46
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Unfortunately I couldn't get my hands on the bot today as I was busy working on mechanical and also it was being used for our driver try out. Hopefully Monday I will be able to map out all off the wheel rotations. I also had two of our mentors go over and double check the wiring and neither could find anything wrong.
Originally Posted by TimTheGreat View Post
Is there a reason your robot drive is *10*,1,2,3? did you mean 0? And make sure the order you set the drive motors is frontLeft, rearLeft, frontRight, rearRight.
No I did mean to say 10. The way our electronics are layed out, it was easier to run a short pwm cable to port 10 on the side car rather than 4. Also note that this is our practice bot and it is running the Crio/associated hardware, not the new RoboRIO.
I changed the signs in the equation because earlier on while troubleshooting we realized that, based on the movements of the wheels we were seeing at the time, there would be a chance that if we changed some of the signs around, we might see the movements we were expecting. Sure enough the robot started driving normally when we changed up the signs.
Originally I didn't even incorporate any gyro code as I just wanted to be sure we had basic functions before going any more complex. After I got the drive functioning properly (using the new equations as seen in my first post), I started working on gyro code. I now have standard mecanum drive working along with proper field centric control (again all using the new equations).
My next step is to try and get a PID loop running that keeps our heading to the desired angle as we are currently experiencing drift in our rotation. I have also been trying to get a velocity PID loop running on our wheels using encoders so that we can ensure that we are getting the desired RPM's out of our wheels.
Unread 24-01-2015, 20:27
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
And what is the problem of just using RobotDrive.MecanumDrive_Cartesian(joystick.getX(), joystick.getY(), joystick2.getX(), 0)?
That should give you exactly what you want without having to mess with the math of it
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 24-01-2015, 20:30
... and if it doesn't then do this.
