Go to Post So basically, the advantage of #35 is that it allows you to be sloppier in your design and fabrication. If you pay close attention to these details, you will never have a problem with #25 chain. - Jim Zondag [more]
Unread 24-01-2015, 16:02
Shaffer Shaffer is offline
FRC #4610
Shaffer is an unknown quantity at this point
Robot won't drive. Help with "command based" programming
Here's our code, including our subsystem (cassie), our command (dothedrive), and our Robot file. It just won't drive no matter what we do. We have one joystick and mecanum drive.
public class cassie extends Subsystem
public SpeedController leftfront = RobotMap.cassieleftfront;
public SpeedController rightfront = RobotMap.cassierightfront;
public SpeedController leftrear = RobotMap.cassieleftrear;
public SpeedController rightrear = RobotMap.cassierightrear;
public RobotDrive wholecassie = RobotMap.cassiewholecassie;
public void initDefaultCommand()
public void takeJoyStickInput(Joystick joy1)
wholecassie.mecanumDrive_Cartesian(joy1.getRawAxis (1), joy1.getRawAxis(2), joy1.getRawAxis(0),0);
public void stop()
wholecassie.mecanumDrive_Cartesian(0, 0, 0,0);
public class dothedrive extends Command
public dothedrive()
requires(Robot.cassie);
protected void initialize()
protected void execute()
Robot.cassie.takeJoyStickInput(Robot.oi.getSidewin der());
protected boolean isFinished()
return false;
protected void end()
Robot.cassie.stop();
protected void interrupted()
public class Robot extends IterativeRobot
Command autonomousCommand;
public static OI oi;
public static cassie cassie;
public static lift lift;
public static grip grip;
public static vision vision;
public void robotInit()
RobotMap.init();
cassie = new cassie();
lift = new lift();
grip = new grip();
vision = new vision();
oi = new OI();
autonomousCommand = new AutonomousCommand();
public void disabledInit()
public void disabledPeriodic()
Scheduler.getInstance().run();
public void autonomousInit()
if (autonomousCommand != null) autonomousCommand.start();
public void autonomousPeriodic()
public void teleopInit() {
if (autonomousCommand != null) autonomousCommand.cancel();
public void teleopPeriodic()
wholecassie.dothedrive(); //this is the line that I'm confused on
public void testPeriodic()
LiveWindow.run();
Unread 24-01-2015, 17:52
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Jalerre is on a distinguished road
Re: Robot won't drive. Help with "command based" programming
I believed the line you are concerned about should be
Scheduler.getInstance().add(teleopCommand);
Substitute teleopCommand with the drive command that you want to run. That command should be instantiated in robotInit. Also the line should be in teleopInit.
Unread 24-01-2015, 21:07
Camilo86's Avatar
Camilo86 Camilo86 is offline
AKA: camilo
FRC #0125 (Nutrons)
Camilo86 is a glorious beacon of lightCamilo86 is a glorious beacon of lightCamilo86 is a glorious beacon of lightCamilo86 is a glorious beacon of lightCamilo86 is a glorious beacon of lightCamilo86 is a glorious beacon of light
If you were to make the command dothedrive the default command for the cassie subsystem, you wouldn't have to specifically call it in the Robot class as long as you have an object of the subsystem there. You can do this by adding this line inside your initDefaultCommand() inside your cassie subsystem
setDefaultCommand(new dothedrive());
It is best to add a default command inside your subsystem than calling all the commands from the Robot class
Unread 25-01-2015, 13:32
FRC #4610
Thank you! I will try these solutions.
