Go to Post You Texas boys and your fancy swerve drive. Why don't ya'll come up here to New England? I'm about to saddle me up a skid steer and herd ya'll fellers into a corner. - Tom Bottiglieri [more]
Unread 24-01-2015, 19:54
Sohaib's Avatar
Sohaib Sohaib is offline
AKA: Sohaib Nadeem
FRC #5036 (The Robo Devils)
Sohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of light
Re: Problem with KitBot: Motors move at different speeds
We had a problem with speed controllers malfunctioning last year. Drive the robot forward at full speed (and assuming your using the kit Talon SR Motor Controllers) the light should be solid green when moving forward at full speed. Do this on blocks so you can observe the lights easier. If you have one of the lights on the motor controllers for the left side are different from the rest, your problem is either a connection, or the motor controller itself.
2014 Season:
- Drive Coach
- Rookie All-Star Award (GTR-E)
2015 Season:
- Driver
- Deans List Semi-Finalist (GTR-E)
2016 Season:
- Driver
- Alliance Captain (GTR-E)
Unread 24-01-2015, 21:55
You can do some troubleshooting by only powering one of the motors on each side at a time. Remove the circuit breaker from the power going to the other one. See if one of the motors is turning slower with a given throttle command.
The advice to calibrate the speed controllers is good.
