Go to Post Robotics for me though really is hard to beat. Though tiring and exhausting, the memories you build are priceless. - ShadowKnight [more]
Unread 24-01-2015, 19:56
1629GaCo's Avatar
1629GaCo 1629GaCo is offline
FRC #1629 (GaCo)
1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute
#25 Chain K1 Masterlink
Does anyone know where we can find a K1 or A1 masterlink for #25 Chain? Any help would be greatly appreciated.
Engineering Inspiration
2008,2009,2010,2011, 2011 Championship,
2012 Championship,2013, NOVA District Event 2016, CHS District Championship 2016
Chairmans Award
2010, 2012, 2014, 2015, NOVA District Event 2016
Regional Champions
2006, 2014, 2015, 2016
Unread 24-01-2015, 21:37
zachrobo1's Avatar
zachrobo1 zachrobo1 is offline
AKA: Zach Cloud
FRC #1002 (The CircuitRunners)
zachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of light
Re: #25 Chain K1 Masterlink
I'm not sure if its what you are looking for, but Andymark does have a masterlink for #25 chain (am-0371).
Team 1002 - Website - Facebook - Twitter - Youtube
Unread 24-01-2015, 22:45
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
McMaster has #25 master links I think.
Unread 24-01-2015, 22:58
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
is this what you are referring to?
If so, we too needed these however they were awfully expensive anywhere we looked ($25-$35 for a pack of 5 without shipping). So we were able to actually make them by replacing middle piece in this photo:
with a small bracket I made using a hand drill and file. now all we have to do is buy masterlinks ($1 a piece where we are) and make a piece of sheet metal with a flange to make a $6-$7 part.
Unread 25-01-2015, 00:04
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
In the past, we have taken a normal hex head bolt to the grinder and made something similar to this. This also gives the ability to tension your chain without an idler anywhere.
Also, Vex has their new VersaFrame Roller Chain Mount. You could bolt through three links with this plate and make your own K1 Masterlink of sorts.
I'm right 90% of the time, so why worry about the other 3%?
Unread 25-01-2015, 00:06
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We didn't like the low apparent pull capability of these "links with wings," as the specs indicated we could only get a #4 screw through the #35 version. Instead, we bought some thumbscrews locally. We then drilled holes through the "handle" big enough for one side of the master link to engage, close enough to the edge so we could engage the last small link on the chain. We passed the thread end through a hole in our lift and secured with jam nuts. This also gave us the capability of adjusting chain tension with a wrench. The idea was borrowed from a garage door opener.
Unread 25-01-2015, 02:36
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
What's wrong with just sticking #8 screws through the area between the rollers in the chain?
Unread 25-01-2015, 12:27
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Could be the orientation of the piece they want to mount it to. For instance, the wings on the linked picture above are for mounting something directly behind the holes. If you rotate the chain 90 degrees (ie. screws through the holes in the chain would be parallel to the face you are trying to mount on) then they wouldn't work right out of the box. A COTS solution for this would be nice, but it can be solved easily without one. My team is bending a T Gusset 90 degrees in order to put screws through chain and then mount to a parallel surface.
Unread 25-01-2015, 18:25
Chinske4296 Chinske4296 is offline
FRC #4296
Chinske4296 is an unknown quantity at this point
A local hardware store. We get ours from ACE hardware.
Unread 26-01-2015, 09:40
1629GaCo's Avatar
FRC #1629 (GaCo)
The VersaFrame Roller Chain Mount will work I think, thanks for the replies.
Chairmans Award
Regional Champions
