Go to Post "I need the adjustable hammer" "You mean that wren-" "No, it's a hammer" - Karibou [more]
Unread 25-01-2015, 12:44
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Accessing .mjpg stream from camera to process
Originally Posted by Fauge7 View Post
That class was made for last year's vision system. Also I have tested it this year and does not work.
I also confirm that it works, though CameraServer has a 2-3sec lag compared to SmartDashboard's direct connection which gets a ~100ms lag
Unread 25-01-2015, 19:04
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
what Axis camera? I used an axis m1013 and it did not, maybe I will revisit it.
Unread 26-01-2015, 08:55
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
We were finally able to get it running, but not with the AxisCamera. The robotRio sees the IP camera as cam0, so I was able to use it just like the USB cameras. Thank for the help.
