Go to Post Once I see that it is black with aluminum ends, I only care about the inside. Sort of like Oreo's. - Al Skierkiewicz [more]
Unread 25-01-2015, 11:47
wre136's Avatar
wre136 wre136 is offline
AKA: Will Edds
FRC #2461 (The METAL-SKINS)
wre136 is an unknown quantity at this point
Adjust Sensor Output to be Zero
We are attemping to use the built-in accelerometer in the new RoboRIO (Just for fun), however when we read it while standing still, it reports -0.014. Either way, it does not read 0.
I want to know if there is a built in function in LabVIEW for normalizing the senors or shifting all of its reading to make it 0 or more close to it so that future reading are accurate. In other word, are the any built in VIs to help calibrate sensor input? I recently learned the ability to put a point-by-point median filter on it to help keep it from jumping around but now just need to help offset it back to zero.
Any ideas?
Will
FRC Team 2461 - The METAL-SKINs
Unread 25-01-2015, 13:11
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Re: Adjust Sensor Output to be Zero
Keep in mind that most accelerometers (i have not checked the roboRIO) give acceleration in X, Y and Z. The Z axis is typically straight down and should read the effect of gravity (32.174ft/s2). If the robot is not level, a portion of the gravity value will appear on the X and/or Y sensor.
Was the roboRIO perfectly level and/or did you correct for it's orientation?
Unread 25-01-2015, 13:23
wre136's Avatar
AKA: Will Edds
I am reading both the x and y values from the accelerometer leaving z out of it. However, it is a possibility that might not be level since it on a robot at the moment. That is something I'll verify later.
However, still, is there a way to bring it to 0 pretending that it is level? This would be a technique I would like to be familiar with when dealing with any kind of sensor.
Will
Unread 25-01-2015, 13:31
It is good that you realize the need to do this step of calibration. Keep in mind that all it will do is record a value that will be added or subtracted from each reading. If the library doesn't have this, you can do it yourself immediately after the read.
I just looked, and the accelerometer VIs do not do this for you.
Greg McKaskle
Unread 25-01-2015, 19:56
If you are using a 6-wheel drivetrain like what was provided in the KOP,
The acceleration due to gravity will shift around a little as the robot rocks.
In that case you will need to take readings when the robot is in the two extreme positions, then decide how you want to subtract the sum from future readings.
