Go to Post Anything worth analyzing is worth over-analyzing. And anything worth over-analyzing is worth hyper-analyzing. Ready, go! - Michael Hill [more]
Unread 25-01-2015, 13:47
gastew15's Avatar
gastew15 gastew15 is offline
FRC #3655 (tractor technicians)
gastew15 is an unknown quantity at this point
Unhappy Robot Initilization failure on deploy
I've been trying to deploy the code to our test bot, but I keep getting am error message everytime and after searching around for quite awhile I haven't really gotten any closer to finding out what's wrong so I was hoping someone here could help.
Error Message:
Unhandled exception instantiating robot org.usfirst.frc.team3655.robot.Robot java.lang.ExceptionInInitializerError at [java.lang.Class.forName0(Native Method), java.lang.Class.forName(Class.java:259), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:197)]
Robot class Code
package org.usfirst.frc.team3655.robot;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.command.Command;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
import org.usfirst.frc.team3655.robot.commands.*;
import org.usfirst.frc.team3655.robot.subsystems.*;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Robot extends IterativeRobot
	//Update EVERYtime you make a change to make sure you deployed the correct version!!
	public static final String VERSION = "0.0.04";
	//SubSystem Variables
	public static final Elevator elevator = new Elevator();
	public static final Gyroscope gyro = new Gyroscope();
	public static final MecanumDrive mecanumDrive = new MecanumDrive();
	public static final RotaryEncoder encoder = new RotaryEncoder();
	public static OI oi = new OI();
	//Commands
    Command teleOpDrive;
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
    public void robotInit()
    	System.out.println("Robot Init v: " + VERSION);
		oi = new OI();
        // instantiate the command used for the autonomous period
		teleOpDrive = new TeleOpDrive();
	public void disabledPeriodic()
		Scheduler.getInstance().run();
    public void autonomousInit()
     * This function is called periodically during autonomous
    public void autonomousPeriodic()
    public void teleopInit()
        //Starts TeleOP drive base
        if (teleOpDrive != null) {
        	teleOpDrive.start();
     * This function is called when the disabled button is hit.
     * You can use it to reset subsystems before shutting down.
    public void disabledInit()
    	//Kills the drive base for teleOP
        	teleOpDrive.cancel();
     * This function is called periodically during operator control
    public void teleopPeriodic()
        //Runs the button checking, probably not the best way but it'll work for now.
        oi.teleOpJoyStick();
     * This function is called periodically during test mode
    public void testPeriodic()
        LiveWindow.run();
*I set up most of the command groups to be ran from the OI when a button is pushed if that's helpful as well. Thank you for any help in advance.
