Go to Post Part of Gracious Professionalism is the Professional bit. Doesn't matter if you're a volunteer or a staff member, a failure of this level in the real world would result in getting fired. - [more]
Unread 25-01-2015, 16:16
PredaFran PredaFran is offline
Amateur Programmer
AKA: Francisco
FRC #5285 (Sea Kings Robotics)
Rookie Year: 2015
PredaFran is an unknown quantity at this point
Question Help with Swerve Drive
As a C++ programmer, this is my first year programming with motors,encoders,the roboRio,etc. and my Team has been developing a swerve drive off-season,and my experience is not helping me with it, so i have been doing a lot of research about it, looking for templates,basics but i still cant manage to do it, so i came here to ask help, suggestions, tips. Everything that can help me
Info about the swerve drive: (attached an image)
*4 motors will be linked using chains, in groups, left(upper and lower) and right(upper and lower)
* it will only be able to rotate 180° to the lafet and 180° to the right
* we are still deciding if we are going to use the CANTalons or Victors
All suggestion are accepte
Thanks
Unread 25-01-2015, 16:32
Re: Help with Swerve Drive
swerve has at least 8 motors (4 steering + 4 propulsion). which set of 4 are you referring to above?
Unread 25-01-2015, 16:33
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
Sorry, 4 motors in the wheels, and 2 that move the chains that steer
Unread 25-01-2015, 16:36
So, you have independent control of the wheel speed for each of the 4 wheels, but the front and back wheels on each side are chained together for steering?
Unread 25-01-2015, 16:37
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
Yeah
Unread 25-01-2015, 16:41
Yeah
when you steer the front right wheel to the right, does the rear right wheel steer to the right also, or to the left?
Unread 25-01-2015, 16:45
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
to the right too
Unread 25-01-2015, 16:53
to the right too
What kind of driver interface do you have in mind?
Unread 25-01-2015, 16:57
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
Smartdashboard
Unread 25-01-2015, 17:06
Smartdashboard
Configured how? What is the interface presented to the driver?
Unread 25-01-2015, 17:08
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
wait, sorry for that, we are going to use the FRC driver station
Unread 25-01-2015, 17:12
So, no joysticks. No Xbox controller. Just the FRC Driver station?
Unread 25-01-2015, 17:17
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
ohh, didnt get that, we are going to use the 3d extreme pro joystick for the driver, because its 3-axis
Unread 25-01-2015, 17:19
ohh, didnt gert that, we are going to use the 3d extreme pro joystick for the driver, because its 3-axis
What does your drive team want each axis to do?
Unread 25-01-2015, 17:23
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
X-Axis: left, right
Y-Axis: fowards and backwards
y-rotate: rotate in the place and while moving
By the way, thanks a lot for the help so far, we really appreciate it
