Go to Post As you get more into your years in FRC, you start becoming friends with more people. You should try it out. Robotics people are pretty nice. - [more]
Unread 25-01-2015, 17:33
howe howe is offline
FRC #5099
howe is a splendid one to beholdhowe is a splendid one to beholdhowe is a splendid one to beholdhowe is a splendid one to beholdhowe is a splendid one to beholdhowe is a splendid one to beholdhowe is a splendid one to behold
Mecanum wheels under varying loads
Has anyone experienced problems with mecanum wheels when the weight distribution changes? For example: picking up bins and or containers which would heavily load one pair of wheels and lessen the load on the others if the payload is cantilevered. Thank you.
Unread 25-01-2015, 17:47
Robot Sans Robot Sans is offline
robots for life
Robot Sans is an unknown quantity at this point
Re: Mecanum wheels under varying loads
I have seen mecanum not perform to well in situations where the center of mass is closer to one wheel than the others but it is something that can be fixed with clever coding, use of encoders and a accelerometer. A more mechanical solution would be to add a pair of wheels closer to the load, which could be free spinning and even the weight difference.
Unread 25-01-2015, 17:51
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
If you do a search, you'll find that this topic has been covered ad nauseum. But to give you the Reader's Digest version, yes, they will react to disproportionate loading. It is probably the biggest drawback to this drive system. It can be compensated for by the driver and somewhat in programming. You do have to ensure, however, that all wheels are in constant contact with the ground (or platform).
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2016 Utah Regional- Engineering Inspiration
2016 Utah Regional- Dean's List Semi-Finalist- Ed O'Connor
2016 Utah Regional- Dean's List Semi-Finalist- Emily Ferrari
2016 Utah Regional- 3rd seed
2016 SBPLI Regional- Finalist, 6th seed
2016 SBPLI Regional- Gracious Professionalism Award
Unread 25-01-2015, 18:12
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Can you describe in more detail this method? I am having trouble visualizing what you mean.
Unread 25-01-2015, 18:15
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
A set of idler wheels...So you have your regular 4 wheel mecanum drive but you add non powered omniwheels of the same size in between the two. That is what I got from it at least. I dont get the mechanics of how it would help though.
Unread 25-01-2015, 18:16
Are you suggesting weight-bearing non-powered wheels? What kind of wheels?
Unread 26-01-2015, 01:25
FRC #5099
I searched ad nauseum before posting my question with no result.
Please point me to the threads or at least give me some key words for my search.
Thanks
Unread 26-01-2015, 01:28
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Thanks
'Ad nauseum' is just a latin term for 'continued until its sickening' (until nausea)
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 26-01-2015, 02:08
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We haven't tried to climb onto platforms, but 3946 has experience with mecanums that were WAY out of balance. Our competition robot last year wasn't too bad, but our proto'bot, made mostly of 2"x4"s, only put about 10# of force on the left front wheel (total weight in excess of 100#). Our drivers learned to compensate well enough that a casual observer at practice would not have suspected how out-of-balance we were. I demo'd "Woodie" at my office with absolutely zero drive practice, and impressed my co-workers (mostly scientists and engineers) with the capabilities of mecanum - I could execute all sorts of translation as well as rotation.
Unread 26-01-2015, 09:06
FRC #5099
Duh, I just don't know what possessed me to type "ad nauseum" into the search bar BEFORE I even posted the question, foolish me.
Now seriously, how about showing some gracious professionalism and post the urls of the threads where the topic of shifting load has been discussed previously? I have gone through several pages searching simply under mecanum in addition to other key words I thought appropriate. It would be nice to know how others have modified their code or driving style to compensate as mentioned in some of the responses.
Thanks,
howe
Unread 26-01-2015, 09:58
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
http://www.chiefdelphi.com/forums/sh...hreadid=133086
http://www.chiefdelphi.com/forums/sh...hreadid=132855
http://www.chiefdelphi.com/forums/sh...hreadid=121317
Google search terms:
mecanum wheel load uneven site:chiefdelphi.com
I usually have much better luck with Google's search than Chief Delphi's.
Unread 26-01-2015, 12:11
dellagd's Avatar
AKA: Griffin D
Ive also been curious about 'perfecting' a mecanum drive system by taking the load on each wheel and programming the drive to account for the uneven loading. All papers I found only referenced the geometric center of the base, not the center of gravity. I have a pretty good understanding of how they work, and I feel like there should be a way to incorporate the different normal forces into the reverse kinematics, but unfortunately I've come up short on figuring out the calculation myself.
So I'll ask too: Has anyone ever done a write up on the reverse kinematics with uneven loading or even written some code to deal with it? This seems like something Ether would have addressed in the past, but I can't find anything for it.
Unread 26-01-2015, 12:17
robots for life
Yup, thats what i was thinking. They would have to be low friction but not omni-directional. Plastic wheels would be ideal.
Unread 26-01-2015, 12:21
assuming each wheel is being driven at the kinematically correct speed, any deviation from the kinematically predicted behavior, due to uneven loading, would mean that the bot is no longer behaving "holonomically" -- there is wheel scrub -- and this would require an analysis of the forces involved.
Unread 26-01-2015, 12:30
dellagd's Avatar
AKA: Griffin D
Interesting. I'm guessing doing the complete analysis would be pretty complicated if there aren't any papers about it. I wonder if a good estimation could be made that works well enough in practice?
